I am having difficulty with this problem from chapter 8 in Spivak's Calculus, any help is appreciated.
(a) Suppose that $y - x > 1$. Prove that there is an integer $k$ such that $x < k < y$. Hint: Let $l$ be the largest integer satisfying $l \le x$, and consider $l + 1$.
(b) Suppose $x < y$. Prove that there is a rational number $r$ such that $x < r < y$. Hint: If $1/n < y-x$, then $ny - nx > 1$
(c) Suppose that $r < s$ are rational numbers. Prove that there is an irrational number between $r$ and $s$. Hint: As a start, you know that there is an irrational number between $0$ and $1$.
(d) Suppose that $x < y$. Prove that there is an irrational number between $x$ and $y$. Hint: It is unnecessary to do any more work; this follows from (b) and (c).
ano
  • 95
The part of this that involves the least-upper-bound property is (b). You know $y-x>0$, so how do you know that there is some integer $n>0$ such that $1/n<y-x$?
If there is none, then every positive integer $n$ is less than $1/(y-x)$. That means the set of all positive integers has an upper bound in $\mathbb R$; hence a least upper bound in $\mathbb R$. Call that least upper bound $c$. Then $c-1$ is not an upper bound, so there is some integer $n>c-1$. So $n+1>c$ and $n$ is an integer, and we have a contradiction.
  • (b) doesn't require the least upper bound property. Just that the reals are archimedean (which is usually proven using that they have the least upper bound property, admittedly). The conclusion is true for the rationals as well. – kahen Jun 11 '13 at 23:27
  • @kahen : The fact that the reals are Archimedean is indeed enough, and it is weaker than the least upper-bound-property, BUT how does one prove the reals are Archimedean in the context of Spivak's book without using the least-upper-bound property? Spivak says the reals are a complete ordered field. "Complete" means they satisfy the least-upper-bound property. Given that, you then have to prove they're Archimedean. And that's what I did above. – Michael Hardy Jun 11 '13 at 23:30
  • (+1) for verifying the hint. I find it common for people to just assume hints when in fact they require attention. –  Jun 11 '13 at 23:39
(a) Let $l$ be the largest integer satisfying $l \le x$. Then $l + 1 > x$, and we have $$x < l + 1 \le x + 1 < y$$
(b) Assume without loss of generality that $0 < x < y$. Choose $n \in \mathbb{N}$ such that $1/n < y - x$, and let $k$ be the largest positive integer such that $k/n \le x$. Then we have
$$x < \frac{k+1}{n} = \frac{k}{n} + \frac{1}{n} \le x + \frac{1}{n} < y$$
(c) We have
$$r < r + \frac{s-r}{\sqrt{2}} < r + s - r = s$$
(d) We can find rational numbers $r_1$ and $r_2$ such that $$x < r_1 < r_2 < y$$
by (b) and we can find an irrational between $r_1$ and $r_2$ by (c).
Ink
  • 5,234
I'll try and help. Sidht has already done (a) for you, but I'd encourage you to show why such a $l$ exists. I won't do (b) as the hint gives it a way. I'll do (c) for you and you should then be able to work out (d) I hope.
Using the hint, we know there exists an irrational number between $0$ and $1$. Do you really? Lets find one. Almost everyone has seen the proof that $\sqrt{2}$ is irrational and clearly, $$0 < 2 < 4 \implies 0 < \sqrt{2} < 2 \implies 0 < \frac{\sqrt{2}}{2} < 1.$$
Now to the problem, assume that $r < s$ and let $x$ be the irrational we found above between $0$ and $1$. As $0 < x < 1$ and $s - r > 0$ we have,
$$ 0 < x(s-r) < s - r.$$
This implies that,
$$r < x(s-r) + r < s.$$
So $y = x(s-r) + r$ is our irrational between $r$ and $s$. You should check that the product of an irrational and a nonzero rational is irrational and that an irrational plus a rational is still irrational.
Hope this helps!
