Let $n \in \mathbb{N}$, $\Omega$ a non-empty bounded open set of $\mathbb{R}^n$ with Lipschitz boundary and $p \in [1,\infty]$. Define $$V_p:=\bigg\{\overrightarrow{q}\in L^p(\Omega;\mathbb{R}^n) \mid \exists \ f\in L^p(\Omega;\mathbb{R}), \forall \varphi \in C^1_c(\Omega;\mathbb{R}^n), \int_\Omega\overrightarrow{q}\cdot\nabla\varphi\operatorname{d}x = -\int_\Omega f\varphi \operatorname{d}x\bigg\}.$$ This space clearly has the interpretation of being the space of $L^p$ vector fields over $\Omega$ that admits a weak-divergence that lies also in $L^p$ (so, in the sequel, the corresponding $f$ w.r.t. to $\overrightarrow{q}$ in the definition will be denoted by $\operatorname{div}\overrightarrow{q}$).
I can't find in standard textbooks about Sobolev spaces a treatment of those spaces, so I'm wondering where I can find them in the literature. In particular, I have several questions that I want to answer, such as:
- Are those spaces Banach spaces w.r.t. $\overrightarrow{q}\mapsto \| \operatorname{div}\overrightarrow{q} \|_p + \|\overrightarrow{q} \|_p$?
- Do they admit traces on the boundary (or maybe just something that plays the role of the normal component of the trace on the boundary?) and do they have some integrability properties?
- Does the divergence theorem hold? I.e., if $\overrightarrow{\nu}$ is the outward normal of $\Omega$ on $\partial\Omega$, does it hold true that $$\int_{\Omega} \operatorname{div}\overrightarrow{q} \operatorname{d}x = \int_{\partial\Omega} \overrightarrow{q}\cdot\overrightarrow{\nu} \operatorname{d}\mathcal{H}^{n-1},$$ where $\overrightarrow{q}$ over $\partial \Omega$ is the trace of $\overrightarrow{q}$ on $\partial \Omega$ and $\mathcal{H}^{n-1}$ is the $n-1$-dimensional Hausdorff measure?
References are very welcome.
