12
Problem
Robert is playing a game with numbers. If he has the number $x$, then in the next move, he can do one of the following:
  • Replace $x$ by $\lceil{\frac{x^2}{2}}\rceil$
  • Replace $x$ by $\lfloor{\frac{x}{3}}\rfloor$
  • Replace $x$ by $9x+2$
He starts with the number $0$. How many integers less than or equal to $7000$ can he achieve using the above functions?
[It is permitted to use a number greater than $7000$ in the way of achieving the desired numbers.]
My Approach
Call the functions $f_1,f_2,f_3$ respectively. $2$ is easily achievable from $0$ (using $f_3$). I've found that all the integers from $0$ to $10$ are achievable (Though we achieve them in a long way). The numbers get messy when we get ahead further. I can't prove that any number is unachievable. I've noticed that base-$3$ numbers can help for $f_2$ and $f_3$.
How to get ahead further?
Update: Mr. Mike showed that all integers are achievable by this process through codes. Mr. Calvin also gave a partial proof for that. So, a complete proof is needed currently.
F Nishat
  • 707
This is not a valid solution.
Ravi pointed out that there is an error.
Claim: For any integer $n$, there exists integers $K , L \geq 0$ such that $$ n\times 3^K \leq 2 \times 10 ^{2^L} \leq (n+1) \times 3^K.$$
Proof: Working mod $\log 3$, we want to show that there exists a $L > 0$ such that
$$ \frac{\log n - \log 2}{\log 10} \leq 2^L \leq \frac{\log (n+1) - \log 2}{\log 10} \quad \pmod{ \log 3}$$
(I am unable to complete this proof. It requires us to show that $\frac{1}{ \log 3} $ in base 2 has all finite binary strings.)
Corollary: $ b^K a^{L-1} c^2 (0) = n$, where
  • $a(x) = \lceil \frac{ x^2 }{ 2 } \rceil $
  • $b(x) = \lfloor \frac{x}{3} \rfloor $
  • $c(x) = 9x+2$.
Notes
  • As conjectured and established via computer by Steven and Mike respectively, after using $ c(0) = 2, c(2) = 20$, it seems like we don't need the $c(x)$ function anymore.
  • In addition, since $ab(x) \approx b^2a(x) \approx \frac{x^2}{18}$ (but the floor and ceiling functions could get in the way of equality), if there was a sequence to get to $n$ using just $a(x), b(x)$, then it might be reasonable that we could collate $a(x), b(x)$ separately.
  • The above 2 comments could motivate the given solution. However, that's not how I came up with it.
  • Working in base 3 is suggested by functions $b(x), c(x)$, and $bbc(x) = x$.
  • (for me at least) Viewing $b(x)$ as truncating in base 3 and $c(x)$ as appending 02 in base 3, made it much easier to think about these function.
  • Based on initial iterations (esp because I avoided $a(x)$ as that made numbers huge), my guesses for achievable numbers were like A) $6k, 6k+2$, B) $2k$, C) Trenary numbers involving only 0 and 2 (maybe with additional conditions).
  • It is clear that if we only used $b(x), c(x)$, then the base 3 representations are limited to digits of 0 and 2 (and in fact, 2's must be separated by 0's). The followup question is "Can we introduce a digit of 1 in base 3 using $a(x)$"?
  • We could do that with $ a(20) = 200 = 21102_3$, and so I thought that the set of achievable numbers were Numbers in base 3 whose starting digit was 2.
  • Looking at $a^2 (20) = 20000 = 1000102202_3$, I realized that would give us $1$ (and $10_3, 100_3, \ldots)$.
  • With that realization, we simply want the inequality in the claim.
  • Of course, there could be other ways of reaching $n$. One possible approach could be to show that we can reach all even numbers, and then by applying $b(x)$ we can reach all numbers.
Calvin Lin
  • 77,541
  • I think your claim of denseness mod $\log 3$ is not so clear. It's equivalent to saying that $\frac{2^L}{\log 3}$ is dense mod 1, which is equivalent to saying that $\frac{1}{\log 3}$ contains all possible finite binary strings--a weak version of being normal in base 2. I assume this is true but unknown. – Ravi Fernando Apr 20 '21 at 20:01
  • @RaviFernando Normal in base 2 is too strong (and I'm unsure if it's true). The original version can be proved by Pigeonhole principle (and is a standard olympiad problem). Let me add the solution. – Calvin Lin Apr 20 '21 at 20:05
    I think you're confusing multiplication with addition. The standard pigeonhole argument will show that $\mathbb N$ is dense in $\mathbb R/(\alpha \mathbb Z)$ (where $\alpha$ is irrational), or that ${2^n}$ is dense in $\mathbb R^{>0}/\alpha^{\mathbb Z}$ (where $\alpha$ isn't a rational power of $2$). What you need is that ${2^n}$ is dense in $\mathbb R/(\mathbb Z \cdot \log 3)$. This is really nontrivial, in light of my first comment. – Ravi Fernando Apr 20 '21 at 21:53
  • In particular your third spoiler box is incorrect: having $2^a$ and $2^b$ close to each other modulo an additive $B$ tells you nothing about the value of $2^{a-b}$ modulo $B$. – Ravi Fernando Apr 20 '21 at 22:12
    @RaviFernando Ah yes, I stand corrected (and in fact I previously showed that there exists a number where this isn't dense.) Back to the drawing board. – Calvin Lin Apr 20 '21 at 22:36
  • Oh, nice. I guess in the worst case scenario, you could leave the answer up as a conditional proof. I would love to see an unconditional version, though, since it's a clever idea and much more conceptual than the other answers. – Ravi Fernando Apr 20 '21 at 23:07
Too long for a comment, but with the help of a computer, I found that all numbers in $\{1,\dots,7000\}$ are indeed reachable. I verified this with the following Python code, which uses a priority queue to find reachable numbers. The best priority ordering I found was to try the $\lfloor x/3\rfloor$ operation first, then to try the $\lceil x^2/2\rceil$ operation, and resorting to $9x+2$ last.
Try it online!
from heapq import heappush, heappop
targets = set(range(1, 7001)) num_targets_left = 7000
seen = set([0]) Q = [(0,0)]
while num_targets_left > 0: current = heappop(Q)[1] to_add = [(0,current//3), (1,(current*2 + 1)//2), (2,9current + 2)] for (priority_level, num) in to_add: if num not in seen: seen.add(num) heappush(Q, (priority_level, num)) if num <= 7000: targets.remove(num) num_targets_left -= 1
print('All numbers in {1,...,7000} are reachable.')
I found the the hardest number was $6121$. The path that led to it below. Here, third x 7 means you do this $\lfloor x/3\rfloor$ operation $7$ times.
Number          Next operation(s)
0               9x + 2
2               9x + 2
20              half-square
200             third x 3
7               half-square
25              third x 1
8               half-square
32              third x 1
10              half-square
50              third x 1
16              half-square
128             third x 2
14              half-square
98              half-square
4802            third x 5
19              half-square
181             half-square
16381           third x 4
202             half-square
20402           third x 4
251             half-square
31501           third x 4
388             half-square
75272           third x 6
103             half-square
5305            third x 3
196             half-square
19208           third x 2
2134            half-square
2276978         third x 5
9370            half-square
43898450        third x 9
2230            half-square
2486450         third x 6
3410            half-square
5814050         third x 6
7975            half-square
31800313        third x 7
14540           half-square
105705800       third x 8
16111           half-square
129782161       third x 9
6593            half-square
21733825        third x 7
9937            half-square
49371985        third x 8
7525            half-square
28312813        third x 8
4315            half-square
9309613         third x 6
12770           half-square
81536450        third x 8
12427           half-square
77215165        third x 8
11768           half-square
69242912        third x 8
10553           half-square
55682905        third x 7
25460           half-square
324105800       third x 9
16466           half-square
135564578       third x 8
20662           half-square
213459122       third x 8
32534           half-square
529230578       third x 9
26887           half-square
361455385       third x 10
6121
Mike Earnest
  • 84,902
