If we map every integer to a string that represents a rational number, and produce a number different from all the ones listed, we are essentially following Cantor's algorithm. But why does it not apply? Is it because we can't be certain that the number produced is a rational number?
If you have an explicit countable ordering of the rational numbers and an explicit version of Cantor's algorithm (watching out for the $0.5000\ldots=0.4999\ldots$ issue), then this gives you a way of generating a guaranteed irrational number. – Henry May 22 '11 at 21:11
It applies, in the sense that you can carry it out. However, the number you obtain through the process is not a rational (it does not have a periodic decimal expansion).
To be precise, the procedure does not let you guarantee that the number you obtain has a periodic decimal expansion (that is, that it is a rational number), and so you are unable to show that the "diagonal number" is a rational that was not in the original list. In fact, if your original list is given explicitly by some bijection, then one is able to show just as explicitly that the number you obtain is not a rational.
- 417,286
11btw, for anyone interested, there is a nice detailed explanation of exactly this answer here: http://www.mathpages.com/home/kmath371.htm – Christiaan Hattingh Jan 27 '15 at 12:11
3Can you give more detail about how one would show explicitly that the number is not a rational? The document linked in comments just has a hand-waving paragraph for that. – M.M Jul 30 '17 at 23:12
Despite replying to an old post, I would like to supplement things that that I missed out after reading all replies.
Fact:
- $\pi$ is irrational
Cantor's method has 1 property and I will respect it
- The generated new number must be different
Cantor's contradiction makes sense because the new number is
- Real number
- Resulted from the method, which means its different from all enumerated real numbers
The contradiction will makes sense to $\mathbb{Q}$ if the new number is
- Rational number
- Resulted from the method, which means its different from all enumerated rationals
Here's the key. The very method can give this number--$\pi$,
- Rational number (No, it isn't)
- Resulted from the method (Yes, it is different from all since its irrational)
This is how you conclude why is the generated number not necessarily rational, because the method gives a lot of freedom in picking the number
- 354
Can you give the construction that would produce pi. That sounds really interesting – Illusioner_ Apr 03 '25 at 13:09
