Hello so my teacher went over an example in class, and I just wanted to verify I understand it
The example was $$u_t + (1-2u) u_x = 0$$ such that $u(x,0 )= \begin{cases} 0 & x\leq 0 \\ 0.5 & \geq 1 \\ x/2 & \text{otherwise} \end{cases} $ and we wanted to compute the velocity of the shock for the initial conditions. We said in class that we will denote it $u_s$ and it is defined as follows
$u_s = \frac{F^+ - F^-}{u^+ - u^-}$, where $F^+$ is the right flux , where the Flux is defined as $F = v(u) u$ and we assume $v(u) = 1 - u$. So in this case
$u_s = \frac{F^+ - F^-}{u^+ - u^-} = \frac{0.5*0.5 - 0*1}{0.5 - 0}= 0.5$
My question is two fold,
Is it normal to assume $v$ which corresponds to the velocity to be equal to $1- u$ and what is the physical interpretation of this in terms of the traffic flow application? My guess is that we are saying as there is more density of cars the speed of the cars is slowing down.
When we computed the speed of the shock we took into account only $0$ and $.5$, but I think if we draw the characteristics we have characteristics from the middle region corresponding to $x/2$ also intersecting at the point (1,1), so shouldn't the shock speed involve them as well?
Thank you for reading this.
