after playing around with absolute value for a little, i noticed that $|a + b| + |a - b|$ always appeared to be the larger of $a$ and $b$ multiplied by $2$, whenever both $a$ and $b$ were positive.
$$ |a + b| + |a - b| = \begin{cases} 2a, & \text{if $a \ge b$} \\ 2b, & \text{if $a < b$} \end{cases} $$
can this be proven to always be the case, and if so, how do i prove it?
Bill Dubuque
  • 282,220
  • This is not true if you allow $a,b$ to be negative – Hagen von Eitzen Feb 01 '21 at 21:06
  • oh right i forgot about that, sorry. though if a and b had to be positive, would this always be the case? –  Feb 01 '21 at 21:07
  • Do you mean the larger of $|a|$ or $|b|$ rather than $a$ and $b$? (I think it is true then. You could prove it by just splitting into cases based on the sign of the terms $a$, $b$, $a+b$, and $a-b$, though that'd be a bit painful) – Milo Brandt Feb 01 '21 at 21:07
  • Also: https://math.stackexchange.com/q/1210728/42969, https://math.stackexchange.com/q/2950149/42969, https://math.stackexchange.com/q/2285899/42969. – Martin R Feb 01 '21 at 21:24
  • If $a\ge b$ then $|a-b|=a-b$ and $\max\{a,b\}=a$, and $$ a+b+|a-b|=a+b+a-b=2a=2\max\{a,b\}.$$
  • If $a\le b$ then $|a-b|=-(a-b)=b-a$ and $\max\{a,b\}=b$, and $$ a+b+|a-b|=a+b+b-a=2b=2\max\{a,b\}.$$
As this covers all cases for real $a,b$, we have $$ a+b+|a-b|=2\max\{a,b\}$$ for all $a,b\in\Bbb R$.
Answer posted to provide industrial strength approach for new students.
To prove:
$|a + b| + |a - b| = 2\max(a,b).$
Either $a \geq b,$ or $a < b.$
Further, either $(a+b) \geq 0$ or $(a+b) < 0.$
Case 1:
$a \geq b$ and $(a+b) \geq 0.$
Then $|a + b| + |a - b| = (a+b) + (a-b) = 2a = 2\max(a,b).$
The assertion is always true in this case.
Case 2:
$a \geq b$ and $(a+b) < 0.$
Then $|a + b| + |a - b| = -(a + b) + (a - b) = -2b.$
$2a = 2\max(a,b).$
The assertion is not always true in this case.
Case 3:
$a < b$ and $(a+b) \geq 0.$
Then $|a + b| + |a - b| = (a+b) + (b-a) = 2b = 2\max(a,b).$
Case 4:
$a < b$ and $(a+b) < 0.$
Then $|a + b| + |a - b| = -(a+b) + (b - a) = -2a.$
$2b = 2\max(a,b).$
user2661923
  • 42,303
  • 21
  • 46
