I could not find any elementary proof of the Power Rule for differentiation:
Given $x,r \in \mathbb R$, $x>0$ and a function $f(x)=x^r$, then its derivative is $f'(x)=rx^{r-1}$
Defintion: Let a sequence of rational numbers {$r_n$} tend to $r$ then $x^r=\lim_{r_n \to r}x^{r_n}$.
All the proofs I had seen utilized the derivative of $\log x$ but I dont think this is elementary because one has to show that for $e=\text{Euler's number}$, $t \in \mathbb R$ and $n \in \mathbb N$ $\lim_{n \to \infty}(1+\frac{1}{n})^n=\lim_{t \to 0}(1+t)^\frac{1}{t}=e$ which can be proved using the Power Rule.
Ofcourse the proof for the Power Rule is straight forward if one is familiar with the result of Power Rule if $r$ is a rational number and theorem regarding derivative of a sequence of derivatives that are uniformly convergent.
Gary
  • 36,640
ibnAbu
  • 2,026
    If you want an answer, you first have to tell us how you define the real power of a number. –  Jan 26 '21 at 20:01
    @YvesDaoust definiton added – ibnAbu Jan 26 '21 at 20:10
    I doubt you'd find an "elementary proof". The properties of the exponential function defined this way are hard to prove. For one thing, you need to prove that this is actually well defined: that if ${s_n}$ is a different sequence of rationals converging to $r$, then $\lim_{n\to\infty}x^{r_n} = \lim_{n\to\infty}x^{s_n}$ (and that the limits exist, which you haven't done). Those are highly nontrivial things to establish. Then you need to use the definitions to establish the properties. And then you get nested limits. No matter how you slice it, it's not going to be "elementary". – Arturo Magidin Jan 26 '21 at 23:01
  • @Arturo Magidin . $\frac{x^{r_n}}{x^{s_n}}=x^{r_n-s_n}$ tends to $1$ as $n \to \infty$ because $ |r_n-s_n| \to 0$ – ibnAbu Jan 27 '21 at 12:58
  • @ibnAbu: You are assuming continuity of a function that you haven’t even defined yet; and you did not prove each of the limits exist. Bottom line is that you seem to have a rather idiosyncratic notion of what “elementary” means. On the one hand you object to the inverse function theorem, on the other you are happy to accept “fucntions defined by power series can be differentiated term by term”. You object to theorems on limits of uniformly convergent series What you do or do not mean by “elementary” is impossible to guess. So state explicitly what you will or will not allow, and why. – Arturo Magidin Jan 27 '21 at 14:34
  • Does this answer your question? – Paramanand Singh Jan 28 '21 at 07:21
    You may find more development of the theory of exponential and logarithmic functions based on your definition of $a^b$ in this blog post. – Paramanand Singh Jan 28 '21 at 07:22
  • @Paramanand Singh . Thanks for the link , quite helpful. – ibnAbu Jan 28 '21 at 10:17
7 Answers7
For real exponents in general, I don't think you can avoid the exponential function and the logarithm because the definition of $x^r$ tends to be $\exp(r\log x)$.
However, for integer exponents there are a number of simple proofs. Here is a lesser-known one. Let $f:\mathbb{R}\mapsto\mathbb{R}$ be the function defined by $f(x)=x^n$ for all $x$, with $n \in \mathbb{N}$. We find that \begin{align} f'(a) &= \lim_{x \to a}\frac{f(x)-f(a)}{x-a} \\[6pt] &= \lim_{x \to a}\frac{x^n-a^n}{x-a} \\[6pt] &= \lim_{x \to a}\frac{(x-a)(x^{n-1}+x^{n-2}a+x^{n-3}a^2+\ldots+xa^{n-2}+a^{n-1})}{x-a} \\[6pt] &= \lim_{x \to a}x^{n-1}+x^{n-2}a+x^{n-3}a^2+\ldots+xa^{n-2}+a^{n-1} \\[6pt] &= a^{n-1}+a^{n-2}a+a^{n-3}a^2+\ldots+aa^{n-2}+a^{n-1}\\[6pt] &= \underbrace{a^{n-1}+a^{n-1}+a^{n-1}+\ldots+a^{n-1}+a^{n-1}}_{\text{$n$ terms}}\\[6pt] &= na^{n-1}\blacksquare \end{align} This proof can be extended to negative integer exponents by writing $x^{-n}$ as $1/x^n$ and using the quotient rule.
Joe
  • 22,603
  • Thanks for your answer for the integer case. Is there elementary proof for $\lim_{n \to \infty}(1+\frac{1}{n})^n=\lim_{t \to 0}(1+t)^\frac{1}{t}=e$ ? – ibnAbu Jan 26 '21 at 20:42
  • @ibnAbu Certainly. (And it can also be done without using the power rule, if that's what you're looking for.) But the answer depends on how you define $e$ (or $e^x$ more generally). – Joe Jan 26 '21 at 20:58
  • You can show by elementary means that $(1+1/n)^n$ is increasing and $(1+1/n)^{n+1}$ is decreasing. They have a common limit, Let's call it "$e$". – marty cohen Jan 26 '21 at 23:02
For $r\in\mathbb{R}$, to prove that $f(x)=x^{r}\implies f'(x)=rx^{r-1}$ We need two lemmas :
Lemma $(1)$ : Consider the function $E(x)=\displaystyle\sum_{n=0}^{+\infty}\frac{x^{n}}{n!}$. We claim that $E'(x)=E(x)$.
Proof : Let $x\in\mathbb{R}$ with $h\neq0$, we define $\tau(h)=\displaystyle\frac{f(x+h)-f(x)}{h}=\frac{E(x+h)-E(x)}{h}$. Since $E(x+y)=E(x)E(y)$, then we have that : $$ \tau(h)=\displaystyle\frac{f(x+h)-f(x)}{h}=\frac{E(x+h)-E(x)}{h}=E(x)\cdot\frac{E(h)-1}{h} $$ Thus we need to prove that $\displaystyle\lim_{h\to 0}\frac{E(h)-1}{h}=1$. Note that : \begin{align*} \frac{E(h)-1}{h}&=\frac{1}{h}\left(\left(1+h+\frac{h^{2}}{2!}+\cdots\right)-1\right) \\ &=1+\frac{h}{2!}+\frac{h^{2}}{3!}+\frac{h^{3}}{4!}+\cdots \\ \implies\left|\frac{E(h)-1}{h}-1\right|&=\left|\frac{h}{2!}+\frac{h^{2}}{3!}+\frac{h^{3}}{4!}+\cdots\right| \\ &\leq\frac{|h|}{2!}+\frac{|h|^{2}}{3!}+\frac{|h|^{3}}{4!}+\cdots \\ &=\underbrace{|h|}_{\to0}\underbrace{\left(\frac{1}{2!}+\frac{|h|}{3!}+\frac{|h|^{2}}{4!}+\cdots\right)}_{\text{bounded}} \end{align*} Since $\displaystyle\lim_{h\to 0}|h|=0$, and if we can show that the other part is bounded, then the overall limit is $0$. Let $0<|h|<1$, we note that the chosen interval of $h$ is due to our interest of $h$ being close to $0$. We have that : \begin{align*} &\left|\frac{E(h)-1}{h}-1\right|=|h|\left(\frac{1}{2!}+\frac{1}{3!}+\frac{1}{4!}+\cdots\right)=|h|\underbrace{\sum_{n=2}^{+\infty}\frac{1}{n!}}_{\text{converges}} \\ \implies\lim_{h\to 0}&\left|\frac{E(h)-1}{h}-1\right|=\lim_{h\to 0}|h|\sum_{n=2}^{+\infty}\frac{1}{n!}=0 \end{align*} Therefore, by sandwich theorem : $$ \lim_{h\to 0}\left|\frac{E(h)-1}{h}-1\right|=0\implies\lim{h\to 0}\frac{E(h)-1}{h}=1 $$ Hence $\displaystyle\lim_{h\to 0}\tau(h)=\lim_{h\to 0}E(x)\cdot\frac{E(h)-1}{h}=E(x)$, $\forall x\in\mathbb{R}$ with $E'(x)=E(x)$.
Lemma $(2)$ : Let $g(x)=\ln(x)$, we claim that $\displaystyle g'(x)=\frac{1}{x}$, $\forall x>0$.
Proof : Let $x_{0}\in(0,+\infty)$ with $x_{0}\neq x$, let $\displaystyle\phi(x):=\frac{\ln(x)-\ln(x_{0})}{x-x_{0}}$. Moreover, there exists $t_{x}\in\mathbb{R}$ with $e^{t_{x}}=x$ and there exists $t_{0}\in\mathbb{R}$ with $e^{t_{0}}=x_{0}$. Thus, we have that :$$\displaystyle\phi(x)=\frac{t_{x}-t_{0}}{e^{t_{x}}-e^{t_{0}}}=\displaystyle\frac{1}{\displaystyle\frac{e^{t_{x}}-e^{t_{0}}}{t_{x}-t_{0}}}$$ Notice that $\ln(x)$ is continuous and that $\ln(x)=t_{x}$ and $\ln(x_{0})=t_{0}$. Thus, we have that : \begin{align*} &\lim_{x\to x_{0}}\ln(x)=\ln(x_{0})=t_{0} \\ \implies&\lim_{x\to x_{0}}\phi(x)=\lim_{x\to x_{0}}\frac{\ln(x)-\ln(x_{0})}{x-x_{0}}\\ &\;\qquad\qquad=\frac{1}{(e^{t})'|_{t=t_{0}}}=\frac{1}{e^{t_{0}}}=\frac{1}{x_{0}} \end{align*} Therefore, $g$ is differentiable at $x_{0}$ and $g'(x_{0})=\displaystyle\frac{1}{x_{0}}$, $\forall x_{0}\in(0,+\infty)$.
Conclusion : We have that $f(x)=x^{r}=e^{\ln(x^{r})}=e^{r\ln(x)}$. We note that $f$ is the composition of $e^{x}$ and $r\ln(x)$ that are both differentiable. Thus : $$ f'(x)=(r\ln(x))'(e^{x})'|_{x=r\ln(x)} =\frac{r}{x}e^{r\ln(x)}=\frac{r}{x}x^{r}=rx^{r-1} $$
B E I R U T
  • 1,836
  • Lemma 1 is easily a consequence of the fact that absolutely convergent power series can be differentiated term by term – ibnAbu Jan 26 '21 at 23:04
  • Indeed you are correct but to be as much rigorous as possible, I used the definition of differentiability. – B E I R U T Jan 26 '21 at 23:06
  • I didn't see how lemma 2 is elementary – ibnAbu Jan 26 '21 at 23:07
    @ibnAbu: And that (absolutely convergent series power series can be differentiated term by term) is hardly an "elementary result". Perhaps you should add your definition of "elementary"... especially in light of your last comment. – Arturo Magidin Jan 26 '21 at 23:07
  • For Lemma $(2)$, note that $\ln(x)$ is the inverse function of $E(x):=e^{x}$. That is to say, for a mapping $g : (0,+\infty)\mapsto\mathbb{R}$, there exists a bijective mapping $g^{-1} : \mathbb{R}\mapsto(0,+\infty)$. So notice that $g(y)=\ln(y)$ is defined by the following implication : $$x=\ln(y)\iff e^{x}=y$$ – B E I R U T Jan 26 '21 at 23:12
For positive integer $r$, we can use induction.
True for $r=1$: $(x^1)' = x' = 1 = 1x^0$.
If true for $r$, $(x^{r+1})' = (x\ x^r)' = x'x^r+x(x^r)' =x^r+x(rx^{r-1}) =x^r+rx^r = (r+1)x^r $.
marty cohen
  • 110,450
I think this is elementary as it requires:
1-Definition of continuity and derivative
2-Binomial Theorem ( which I think is quite elementary)
3-Geometric series
4-Series convergence test by comparison
5-limit of Uniformly Convergent series is continuous
It suffice to prove $\frac{d}{dx}\log{x}=\frac{1}{x}$ using elementary results
$x > 0$ , $n \in N$
define $e=\lim_{n \to \infty}(1+\frac{1}{n})^n$ which exists according to binomial theorem and comparison with geometric series
define $g(x)=\lim_{n \to \infty}(1+\frac{x}{n})^n$ which exists as shown below
$h(x)=\sum_{n=0}^\infty \frac{x^n}{n!}$ which exists by comparison with geometric series and is uniformly convergent
using binomial theorem $g(x)=h(x)$
because $x>0$, $g(x)$ is increasing on $[0,\infty)$
$k,m,j \in N$
$ y \in Q$
$y=\frac{k}{m}$
$g(y)=\lim_{n \to \infty}((1+\frac{y}{n})^{\frac{n}{y}})^y$
set $n=kj$
$g(y)=\lim_{j \to \infty}((1+\frac{1}{mj})^{mj})^y=e^y$
because $g(x)$ is increasing for every $x>0$ we can find two rational numbers $p,q$ and $q>p$ such that $g(p)\le g(x) \le g(q)$
since $h(x)$ is continuous the limit $\lim_{r_n \to r}e^{r_n}=\lim_{r_n \to r}h(r_n)=h(r)$ , where $\{r_n\}$ is a sequence of rational numbers converging to $r$
So it makes sense to define $e^r=\lim_{r_n \to r}e^{r_n}$
since we can let $ p \to q$ and $e^x$ is continuous ,this implies $e^x=h(x)$
$\frac{dh}{dx}=\lim_{t \to 0} e^x\frac{e^t-1}{t}=\lim_{t \to 0} e^x\frac{\sum_{n=1}^\infty \frac{t^n}{n!}}{t} = e^x$
$x=e^{\log{x}}$
taking derivative of both sides and using chain rule
$1=e^{\log{x}}\frac{d}{dx}\log{x}$
$\frac{d}{dx}\log{x}=\frac{1}{e^{\log{x}}}=\frac{1}{x}$
ibnAbu
  • 2,026
You're not going to get an elementary proof for real $r$ in general. But you can go a long way by elementary means.
natural $r$:
Use induction starting at $f(x)=x$ and then use the product rule for the inductive step. For $r=0$ the result is trivial.
integer $r$:
Use that $x^{-r}=(x^r)^{-1}$, then apply the chain rule. This way you only need to prove $\frac{\mathrm dx^{-1}}{\mathrm dx}=-x^{-2}$. Which goes like this:
$$\begin{align}\frac{(x+h)^{-1}-x^{-1}}{h}&=\frac{\frac{x}{x(x+h)}-\frac{x+h}{x(x+h)}}{h}\\ &=\frac{-\frac{h}{x(x+h)}}{h}\\ &=-\frac{1}{x(x+h)},\end{align}$$
which goes to $-x^{-2}$ as $h\to0$.
rational $r$:
Use that $x^{\frac pq}=(x^p)^{\frac1q}$ and the chain rule, so you only need to prove the fact for $r=\frac1q,~q\in\mathbb N_{\geq2}$. Which follows from the rule for the derivative of the inverse function, since $x^{\frac1q}$ is the inverse of $x^q$. Exception: at $x=0$ the inverse function rule doesn't work since we would divide by $0$. But for $x=0$, the derivative is again elementary, since $\frac{h^q}{h}=h^{q-1}$ goes to $0$ as $h\to0$ for all $q>1$.
irrational $r$:
This is where elementary means won't help us anymore. But it can be done without logarithms. Let's say $r_n\to r$, where $r_n$ are all rational. We want to calculate the limit
$$\lim_{h\to0}\frac{\lim\limits_{n\to\infty}(x+h)^{r_n}+\lim\limits_{n\to\infty}x^{r_n}}{h}.$$
Using the limit laws we can manipulate this to get
$$\lim_{h\to0}\lim_{n\to\infty}\frac{(x+h)^{r_n}-x^{r_n}}{h}.$$
If we could exchange the two limits, we would get that this is equal to
$$\lim_{n\to\infty}\lim_{h\to0}\frac{(x+h)^{r_n}-x^{r_n}}{h}=\lim_{n\to\infty}\frac{\mathrm dx^{r_n}}{\mathrm dx}=\lim_{n\to\infty}r_n x^{r_n-1}=r x^{r-1},$$
where the last step uses elementary limit laws and your definition of irrational powers. But we need to be able to exchange the limits. There is a theorem which says that if both $\lim_{h\to0} a_n(h)$ and $\lim_{n\to\infty}a_n(h)$ exist and the latter limit is uniform if we consider $a_n$ as a sequence of functions of $h$, then we are allowed to exchange the limits. But I'd classify this theorem as similarly non-elementary as logarithms. Anyway, we now need to prove that
$$\frac{(x+h)^{r_n}-x^{r_n}}{h}$$
converges uniformly as a sequence of functions of $h$. I'm having a hard time doing so right now, but I'm pretty optimistic that it can be proved. You might want to try it as an exercise.
Possibly the most "elementary" way to do it is to define logarithms first, and only later define general exponentials (and not to do it the way you do, except to show the new definition agrees with the standard one for integers and rationals).
For $x\gt 0$, define the function $\log(x)$ be $$\log(x) = \int_1^x \frac{1}{t}\,dt.$$
The following properties are now straightforward:
  1. $\log(x)$ is strictly increasing and differentiable.
  2. $\frac{d}{dx}\log(x) = \frac{d}{dx}\int_1^x\frac{1}{t}\,dt = \frac{1}{x}$.
  3. $\lim_{x\to0^+}\log(x) = -\infty$ and $\lim_{x\to \infty}\log(x)=\infty$.
  4. $\log(1)=0$.
Then we also have, by letting $u=\frac{1}{t}$, that $$\begin{align*} \log\left(\frac{1}{x}\right) &= \int_1^{1/x}\frac{1}{t}\,dt &= \int_1^x u\left(-\frac{u}{u^2}\right)\,du\\ &= -\int_1^x\frac{1}{u}\,du\\ &= -\log(x). \end{align*}$$
Also: fix $a\gt 0$. Then letting $au=t$, we have $$\begin{align*} \log(ax) &= \int_1^{ax}\frac{1}{t}\,dt\\ &= \int_{1/a}^x\frac{1}{au}a\,du\\ &= \int_{1/a}^x\frac{1}{u}\,du = -\int_1^{1/a}\frac{1}{u}\,du + \int_1^x\frac{1}{u}\,du\\ &= -\log\left(\frac{1}{a}\right) + \log(x)\\ &= \log(a)+\log(x). \end{align*}$$ So now we also have the following further properties: for $a,b\gt 0$,
  1. $\log(ab)=\log(a)+\log(b)$.
  2. $\log(a/b)=\log(a)-\log(b)$.
By induction, it follows that for positive integers $n\gt 0$, $\log(a^n) = n\log(a)$; and that $\log(a^{-n}) = -n\log(a)$.
If $r=\frac{p}{q}$ is a rational, with $q\gt 0$, then we have that $$q\log(a^{p/q}) = \log(a^{p}) = p\log(a),$$ hence $\log(a^{p/q}) = \frac{p}{q}\log(a)$.
Now, since $\log(x)$ is strictly increasing, it has an inverse. Let us denote the inverse by $E$. So $E(x)=y$ if and only if $\log(y)=x$. From the properties of $\log(x)$, we get:
  1. $E(x)$ is strictly increasing and differentiable.
  2. Since $x=\log(E(x))$, differentiating both sides and using the Chain Rule we have $$\begin{align*} 1 &= \frac{1}{E(x)}\left(\frac{d}{dx}E(x)\right)\\ E(x) &= \frac{d}{dx}E(x). \end{align*}$$
  3. $\lim_{x\to-\infty}E(x) = 0^+$ (that is, $E(x)$ is positive for all $x$, and approaches $0$ as $x\to-\infty$), and $\lim_{x\to\infty}E(x)=\infty$.
  4. $E(0)=1$.
Now, say $E(a)=r$ and $E(b)=s$. Then $\log(r)=a$ and $\log(s)=b$. Therefore,$a+b=\log(r)+\log(s) = \log(rs)$ and $a-b=\log(r)-\log(s)=\log(r/s)$, hence $$E(a+b) = rs = E(a)E(b)\quad\text{and}\quad E(a-b) = \frac{E(a)}{E(b)}.$$ giving 5. $E(a)E(b) = E(a+b)$. 6. $\frac{E(a)}{E(b)} = E(a-b)$.
If $E(a)=r$ and $n\gt 0$ is an integer, then by induction we have that $E(na) = E(a)^n = r^n = E(na)$. This immediately extends to negative integers, and finally to rational exponents, so that $E(a)^{p/q} = E(ap/q)$ for all integers $p,q$, with $q\gt 0$.
Definition. If $a\gt 0$ and $b$ is any real number we define $\exp(a,b) = E(b\log(a))$.
Proposition. If $b$ is a rational number, then $\exp(a,b)=a^b$.
Proof. First, assume $b$ is a positive integer. By induction: $\exp(a,1) = E(1\log(a)) = E(\log(a)) = a = a^1$. If $\exp(a,k) = a^k$, then $$\exp(a,k+1) = E((k+1)\log(a)) = E(k\log(a)+\log(a)) = E(k\log(a))E(\log(a)) = a^ka = a^{k+1}.$$ Thus, the proposition holds for $b$ a positive integer.
If $b$ is a negative integer, then $$\exp(a,b) = E(b\log(a)) = E(-(-b)\log(a)) = \frac{1}{E((-b)\log(a))} = \frac{1}{a^{-b}} = a^b.$$
Finally, if $b=\frac{p}{q}$ with $p,q$ integers and $q\gt 0$, then $$(\exp(a,b))^q = (E(b\log(a)))^q = E(qb\log(a)) = E(p\log(a)) = a^p,$$ so taking $q$th roots on both sides we get $\exp(a,b) = a^{p/q}=a^b$. $\Box$
In light of the proposition, we simply write $a^b$ instead of $\exp(a,b)$; we know it agrees with the "old" definition when $b$ is a rational number.
Thus, if $\{q_n\}_{n\in\mathbb{N}}$ is a sequence of rational numbers and $q_n\to r$, then $$\lim_{n\to\infty} a^{q_n} = \lim_{n\to\infty}E^{q_n\log(a)} = E\left(\lim_{n\to\infty}q_n\log(a)\right) = E(r\log(a)) = a^r,$$ since $E$ is continuous. Thus, this definition agrees with the definition you propose for $a^r$.
So, finally, using the Chain Rule, we get $$\begin{align*} \frac{d}{dx}x^r &= \frac{d}{dx} E(r\log(x)) \\ &= E(r\log(x))\left(\frac{d}{dx}r\log(x)\right) \\ &= \frac{r}{x}E^(r\log(x))\\ &= rx^{-1}E(r\log(x))\\ &= rE(-\log(x))E(r\log(x))\\ &= rE(-\log(x)+r\log(x)) = rE((r-1)\log(x))\\ &= rx^{r-1}, \end{align*}$$ giving the desired differentiation formula.
Of course, we let $e$ be the solution to $\log(x)=1$, and then we have that $$E(x) = E(x\log(e)) = e^x,$$ which gives us the "usual" notation. Then Taylor's Theorem will give the equivalence of this definition with the power series definition.
Arturo Magidin
  • 417,286
For integer exponent: calculated directly: $$\lim_{\epsilon \to 0} \frac{(x+\epsilon)^{n}-x^{n}}{\epsilon}=\lim_{\epsilon \to 0} \left(nx^{n-1}+\sum_{i=2}^{n}{\epsilon^{i-1}x^{n-i} \binom{n}{i}}\right)=nx^{n-1}$$
For exponent of form $1/n$, where $n$ is integer using composite function derivate where one funtion is the other one's inverse:
$$f'=\frac {1}{g' \circ f}$$
for $f(x)=x^{\frac {1}{n}}$, $g(x)=x^{n}$:
$$f'= \frac {1}{g' \circ f}=\frac {1}{n(x^{\frac {1}{n}})^{n-1}}={\frac {1}{n}}x^{\frac {1}{n}-1}$$
For rational exponent using the composite function derivate:$ (f\circ g)'=(f'\circ g)g'$:
$f=x^{n}$, $g=x^{\frac {1}{m}}$: $$(x^{\frac n m})'=n(x^{\frac 1 m})^{n-1}\frac 1 mx^{\frac 1 m -1}=\frac n mx^{\frac {n-1} m + \frac 1 m -1}=\frac n m x^{\frac n m -1}$$
For irrational exponent the monotonicity of the exponential function is the key. First reduce the task calculating the lim for an expression that contains two elements with irrational exponent, to calculating the lim of an expression that has only one such component:
$$\lim_{e \to 0}\frac {(x+e)^r -x^r} {e}=x^{r-1}\lim_{e \to 0}\frac {(1+ \frac {e}{x})^r - 1}{\frac e x}=x^{r-1}\lim _{\epsilon \to 0}\frac {(1+\epsilon)^r-1}{\epsilon}$$
I applied here an $\epsilon = \frac e x$ substitution.
The definition of power with irrational exponent, combined with the monotonicity of exponential function on rational exponents results in:
if $x > 1$: $x^{r}=\sup_{q\in \mathbb Q,\; 0 \lt q \lt r }x^{q}=\inf_{q\in \mathbb Q,\; q \gt r }x^{q}$
if $0 < x < 1$: $x^{r}=\sup_{q\in \mathbb Q,\; q \gt r }x^{q}=\inf_{q\in \mathbb Q,\; 0 \lt q \lt r }x^{q}$
Based on this, for any $q$, $p$ rational number where $0 <q < r < p$ and $e > -1$:
$$\frac {(1+e)^q-1} {e} \lt\frac {(1+e)^r-1} {e} \lt\frac {(1+e)^p-1} {e}$$
Which implies the relation between the limits when $e$ tends $0$:
$$q=\lim_{e \to 0}\frac {(1+e)^q-1} {e} \le\lim_{e \to 0}\frac {(1+e)^r-1} {e} \le\lim_{e \to 0}\frac {(1+e)^p-1} {e}=p$$
This stands for any $q$, $p$ rationals $0 < q < r < p$. The only number y that satisfies $q \le y \le p$ for any $q$, $p$ rationals $0<q<r<p$ is the number $r$.
