This is exercise $4.3.15$ from the book How to Prove it by Velleman $($$2^{nd}$ edition$)$:
Suppose $R_1$ and $R_2$ are relations on $A$. For each part, give either a proof or a counterexample to justify your answer.
$(a)$ If $R_1$ and $R_2$ are reflexive, must $R_1\setminus R_2$ be reflexive$?$
$(b)$ If $R_1$ and $R_2$ are symmetric, must $R_1\setminus R_2$ be symmetric$?$
$(a)$ If $R_1$ and $R_2$ are transitive, must $R_1\setminus R_2$ be transitive$?$
Here are my answers:
Part $(a)$: Counterexample:
Suppose $A=\{1\}$, $R_1=\{(1,1)\}$, and $R_2=\{(1,1)\}$. Then $R_1\setminus R_2=\{\}$. Thus $R_1$ and $R_2$ are both transitive but $R_1\setminus R_2$ is not transitive and hence a counterexample.
Part $(b)$: Proof:
Suppose $R_1$ and $R_2$ are symmetric. Let $a$ and $b$ be arbitrary elements of $A$ such that $(a,b)\in R_1\setminus R_2$ which means $(a,b)\in R_1$ and $(a,b)\notin R_2$. Since $R_1$ is symmetric, $(b,a)\in R_1$ and since $R_2$ is symmetric, $(b,a)\notin R_2$. Ergo $(b,a)\in R_1\setminus R_2$. Since $a$ and $b$ are arbitrary, $R_1\setminus R_2$ is symmetric. Therefore if $R_1$ and $R_2$ are symmetric then $R_1\setminus R_2$ is symmetric. $Q.E.D.$
Part $(c)$: Counterexample:
Suppose $A=\{1,2,3\}$, $R_1=\{(1,3),(3,2),(1,2)\}$, and $R_2=\{(1,2)\}$. Then $R_1\setminus R_2=\{(1,3),(3,2)\}$. Thus $R_1$ and $R_2$ are both transitive but $R_1\setminus R_2$ is not transitive and hence a counterexample.
Here are my questions:
$1.$ Are my answers to parts $(a)$, $(b)$, and $(c)$ correct$?$
$2.$ I was certain about my answer to part $(c)$ until I saw this post. Is my counterexample a valid one$?$ If yes, then why it seems that there is a discrepancy between my answer and the above linked post$?$
Thanks for your attention.
Edit:
Question $2$ is irrelevant and I see it now. I mixed up the counterexample $(a)$ and counterexample $(c)$ in my mind. Thanks.
    Regarding question $2$, how is the linked post relevant? It concerns the empty relation, which your counterexample is not. – PrincessEev Aug 12 '20 at 07:23
  • @EeveeTrainer You are absolutely right. Thank you. In my mind I mixed up counterexample $(a)$ with counterexample $(c)$. I will edit the post accordingly. – Khashayar Baghizadeh Aug 12 '20 at 07:25
Everythink is perfectly correct. The link you posted is about the empy relation $R$ while in c) neither $R_1$, $R_2$ nor $R_1\backslash R_2$ are empty so it does not apply to your example c).
(a) is fine, minimal counterexample.
To (b) I'd write "Since $R_1$ is symmetric, $(b,a) \in R_1$ and also $(b,a) \notin R_2$ or else $(a,b) \in R_2$, as $R_2$ is symmetric, and we knew $(a,b) \notin R_2$. So $(b,a) \in R_1 \setminus R_2$". (making the small argument using the symmetry of $R_2$ explicit).
To (c): I'd say the example looks good. But part of having an example is showing that actually $R_1,R_2$ are transitive (tedious case checking). It's also part of the solution. So it's somewhat incomplete as it stands now. I don't see the relevance of the linked post, though.
Henno Brandsma
  • 250,824
