I would like to solve the following parameterised definite integral. $$ f(a) = \int_0^1 \frac{\ln\left(ax^2 + 1\right)}{x + 1}\:dx $$ Where $a \in \mathbb{R}^+$
I have tried a few different methods that haven't resulted in anything useful. I was hoping to ask for a starting point on this question.
Note - if possible, I'm trying to resolve this integral using Real Analysis only.
As per a recommendation provided, I will employ Feynman's Trick (coupled with the Dominated Convergence Theorem and Leibniz's Integral Rule) and differentiate. Firstly though, we observe that $f(0) = 0$. We now proceed by differentiating under the curve with respect to $a$:
\begin{align} f'(a)& = \frac{d}{da}\int_0^1 \frac{\ln\left(ax^2 + 1\right)}{x + 1}\:dx = \int_0^1 \frac{\frac{\partial }{\partial a}\big[\ln\left(ax^2 + 1\right)\big]}{x + 1}\:dx \\ & = \int_0^1 \frac{x^2}{ax^2 + 1} \cdot \frac{1}{1 + x}\:dx = \int_0^1 \frac{x^2}{\left(ax^2 + 1\right)\left(x + 1\right)}\:dx \end{align} We now apply a Partial Fraction Decomposition on the integrand: \begin{align} f'(a) &= \int_0^1 \frac{1}{a + 1}\left[\frac{x}{ax^2 + 1} - \frac{1}{ax^2 + 1} + \frac{1}{x + 1}\right]\:dx\\ & = \frac{1}{a + 1}\left[\frac{1}{2a}\ln\left(ax^2 + 1\right) - \frac{1}{\sqrt{a}}\arctan\left( \sqrt{a}x\right) + \ln\left(x + 1\right) \right]_0^1 \\ &= \frac{1}{a + 1}\left[\frac{\ln\left(a + 1\right)}{2a} - \frac{\arctan\left( \sqrt{a}\right) }{\sqrt{a}} + \ln(2) \right] \end{align}
From here, we resolve $f(a)$ by integrating with respect to $a$: \begin{align} f(a) &= \int \frac{1}{a + 1}\left[\frac{\ln\left(a + 1\right)}{2a} - \frac{\arctan\left( \sqrt{a}\right) }{\sqrt{a}} + \ln(2) \right]\:da \\ &= \frac{1}{2}\int \frac{\ln(a + 1)}{a\left(a + 1\right)}\:da - \int \frac{\arctan\left(\sqrt{a}\right)}{\sqrt{a}\left(a + 1\right)} + \ln(2)\int \frac{1}{a + 1}\:da \\ &= \frac{1}{2}A - B + \ln(2)D \end{align} We now resolve each individually (note I will omit the constant of integration till the end). Starting with the easiest $D$: $$ D = \int \frac{1}{a + 1}\:da = \ln(a + 1) $$ We now resolve $A$ by applying a Partial Fraction Decomposition: \begin{align} A &= \int \ln(a + 1) \left[ \frac{1}{a} - \frac{1}{a + 1} \right]\:da = \int \frac{\ln(a + 1)}{a}\:da - \int \frac{\ln(a + 1)}{a + 1}\:da \\ &= -\operatorname{Li}_2(-a) - \frac{1}{2}\ln^2(a + 1) \end{align} We now resolve $B$. Here we make the substitution $a = b^2$, $b > 0$ \begin{align} B = \int \frac{\arctan(b)}{b\left(b^2 + 1\right)} \cdot 2b \:db = 2\int \frac{\arctan(b)}{b^2 + 1}\:db = 2 \cdot \frac{1}{2}\arctan^2(b) = \arctan^2\left(\sqrt{a}\right) \end{align} Thus, we now may form $f(a)$ \begin{align} f(a) &= \frac{1}{2}A - B + \ln(2)D \\ &=\frac{1}{2}\left[-\operatorname{Li}_2(-a) - \frac{1}{2}\ln^2(a + 1) \right] - \arctan^2\left(\sqrt{a}\right) + \ln(2)\ln(a + 1) + C \end{align} Where $C$ is the constant of integration. We resolve $C$ using $f(0) = 0$: \begin{align} f(0) = 0 = \frac{1}{2}\left[-\operatorname{Li}_2(0) - \frac{1}{2}\ln^2(1) \right] - \arctan^2\left(\sqrt{0}\right) + \ln(2)\ln(0 + 1) + C = 0 + C \rightarrow C = 0 \end{align} And so, $$ \int_0^1 \frac{\ln\left(ax^2 + 1\right)}{x + 1}\:dx = \frac{1}{2}\left[-\operatorname{Li}_2(-a) - \frac{1}{2}\ln^2(a + 1) \right] - \arctan^2\left(\sqrt{a}\right) + \ln(2)\ln(a + 1) $$
Feynman's trick seems to be a way $$f(a) = \int_0^1 \frac{\log\left(ax^2 + 1\right)}{x + 1}\,dx$$ $$f'(a) = \int_0^1 \frac{x^2}{(x+1) \left(a x^2+1\right)}\,dx=\frac 1 {a+1} \int_0^1\left(\frac{x-1}{a x^2+1}+\frac{1}{x+1}\right)\,dx$$Assuming $-1\leq \Im\left(\sqrt{a}\right)\leq 1\lor \Re\left(\sqrt{a}\right)>0$ $$f'(a)=\frac{\log (2)}{a+1}+\frac{\log (a+1)}{2 a(a+1)}-\frac{\tan ^{-1}\left(\sqrt{a}\right)}{\sqrt{a} (a+1)}$$ $$\int f'(a)\,da=\log (2) \log (a+1)-\frac{1}{2}\text{Li}_2(-a)-\frac{1}{4} \log ^2(a+1)-\arctan ^{2}\left(\sqrt{a}\right)$$
  • Yes - thank you! I was typing out my solution as per this method before I saw the notification of your answer. I have marked it now. Thanks :-) – David Galea Aug 07 '20 at 05:31
