I would like to find a general solution to the integral: $$I(s,t,k)=\int_0^\infty \frac{\cos(tx)}{x^2+k^2}e^{-sx}dx$$ so far using the substitution $u=\frac xk$ I have managed to reduce this to: $$I(s,t,k)=\frac 1k\int_0^\infty\frac{\cos(tku)}{u^2+1}e^{-sku}du$$ and then by defining $\alpha=tk,\beta=sk$ we can come up with a simpler integral: $$J(\alpha,\beta)=\int_0^\infty\frac{\cos(\alpha u)}{u^2+1}e^{-\beta u}du$$
We can calculate that: $$J_{\beta\beta}=\int_0^\infty\frac{u^2\cos(\alpha u)}{u^2+1}e^{-\beta u}du$$ $$=\int_0^\infty\cos(\alpha u)e^{-\beta u}du-J$$ $$=\frac{\beta}{\beta^2+\alpha^2}-J$$ $$J_{\alpha\alpha}=-J_{\beta\beta}$$
We now know that: $\nabla^2J=0$
Now to form a system of equations I found that: $$J(0,0)=\frac \pi2$$ $$J(\alpha,0)=\frac{\pi}{2}e^{-\alpha}$$ However I am struggling to find a solution to $J(0,\beta)$ although I know that it satisfies the equation: $$K''(\beta)+K(\beta)=\frac 1\beta,K(0)=\frac \pi2$$ It seems clear to me that $\lim_{\beta\to\infty}J(\alpha,\beta)=0$ so if I could solve for $K$ I should have everything I need to try and solve this problem.
I think its obvious but I should add that: $$I(s,t,k)=\frac 1kJ(tk,sk)$$
Basically, could anyone help me find $J(0,\beta)$ or proceed with solving the pde I stated. Thanks!
EDIT
wolfram alpha gives: $$J(0,\beta)=\operatorname{Ci}(b)\sin(b)+\frac{\pi-2\operatorname{Si}(b)}{2}\cos(b)$$
Henry Lee
  • 12,554
  • This last value in the edit makes me think that there will not be a nice solution to $J$ but I would love to see if any progress can be made! – Henry Lee Jul 13 '20 at 20:25
  • It's too late for me to give the problem a go, but you might be able to adapt the solution method given by Luis Sierra here. – Matthew Cassell Jul 13 '20 at 20:30
  • yes that question is what gave me the motivation to continue with this problem that I had left for a while, I think the additional term seems to make the pde particularly difficult – Henry Lee Jul 13 '20 at 20:33
    I get $$I''(t) - k^2I(t) = s/(t^2-s^2)$$, Idk how to solve this, though. – Nikunj Jul 13 '20 at 20:33
You can perform a further reduction: $$ J(\alpha,\beta)=\int_{0}^{+\infty}\frac{\cos(\alpha u)}{u^2+1}e^{-\beta u}\,du =\text{Re}\int_{0}^{+\infty}\frac{1}{u^2+1}e^{-(\beta-\alpha i)u}\,du$$ thus all you need is the Laplace transform of $\frac{1}{u^2+1}$: $$ K(c) = \int_{0}^{+\infty}\frac{e^{-cu}}{u^2+1}=\int_{0}^{\pi/2}\exp\left(-c\tan\theta\right)\,d\theta,\qquad c\in\mathbb{C},\text{Re}(c)\geq 0.$$ By the self-adjointness of the Laplace transform and the fact that $\mathcal{L}^{-1}\left(\frac{1}{u^2+1}\right)=\sin(s), \mathcal{L}(e^{-cu})=\frac{1}{c+s} $ we have $$ K(c) = \int_{0}^{+\infty}\frac{\sin(s)}{s+c} \,ds $$ and the relation with the sine and cosine integrals is now obvious.
Jack D'Aurizio
  • 361,689
In the same lines as Jack D´Aurizio did, start with your integral
$$J\left(a,b,c\right)=\int_{0}^{\infty} \frac{\cos(ax)e^{-cx}}{b^{2}+x^{2}}dx$$
which can be rewriten as
$$J\left(a,b,c\right)=\text{Re}\left\{\frac{1}{b}\int_{0}^{\infty} \frac{e^{-x(b(c-ia))}}{1+x^{2}}dx\right\}$$
set $(b(c-ia))=s$ to get
$$\text{I}\left(s,b\right)=\frac{1}{b}\int_{0}^{\infty} \frac{e^{-sx}}{1+x^{2}}dx$$
to simplify, consider the version
$$\text{I}\left(s\right)=\int_{0}^{\infty} \frac{e^{-sx}}{1+x^{2}}dx$$
Now differentiate $\text{I}\left(s\right)$ with respect to $s$ twice to get
$$I''\left(s\right)=\int_{0}^{\infty} \frac{x^{2}e^{-sx}}{1+x^{2}}dx$$
Adding $I''\left(s\right)$ and $I\left(s\right)$
$$I''\left(s\right)+I\left(s\right)=\int_{0}^{\infty} e^{-sx}dx=\frac{1}{s}$$
This non homogeneous second order ODE can be solved by the method of variation of parameters. The two linear independent solutions of the homogeneous equations are given by
$$u_{1}(s)=\cos(s)$$
$$u_{2}(s)=\sin(s)$$
The the general solution is given by
$$I_{g}\left(s\right)=A(s)\cos(s)+B(s)\sin(s)$$
where
$$A(s)=-\int_{}^{}\frac{1}{W}u_{2}(s)f(s)ds$$ and
$$B(s)=\int_{}^{}\frac{1}{W}u_{1}(s)f(s)ds $$
$W=u_{1}u_{2}'-u_{2}u_{1}'$ is the Wronskian which is $1$ here, and $f(s)=\frac{1}{s}$
putting all together
$$I_{g}\left(s\right)=-\cos(s)\int_{}^{s}\frac{\sin(t)}{t}dt +\sin(s)\int_{}^{s}\frac{\cos(t)}{t}dt$$
But $I(s)$ and all its derivatives vanish at $s=\infty$, and therefore
$$I_{g}\left(s\right)=\cos(s)\int_{s}^{\infty}\frac{\sin(t)}{t}dt -\sin(s)\int_{s}^{\infty}\frac{\cos(t)}{t}dt$$
$$\boxed{I\left(s\right)=\sin(s)Ci(s)+\cos(s)\left(\frac{\pi}{2}-Si(s)\right)}$$
Ricardo770
  • 2,881
I have managed to solve this in the end by assuming that the equation $J$ is separable then solving for this, and the answers lining up with the boundary conditions that be know for $J$, back substituting then gives us: $$I(s,t,k)=\int_0^\infty\frac{\cos(tx)}{x^2+k^2}e^{-sx}dx=\frac{\pi e^{-tk}}{2k}\left[\operatorname{Ci}(sk)\sin(sk)+\frac{\pi-2\operatorname{Si}(sk)}{2}\cos(sk)\right]$$
Henry Lee
  • 12,554
