8
Community!
I'm working on the following problem: Let $X$ be a non-empty set and $d_1,d_2$ metrics on X. Show that the following conditions are equivalent:
1) $d_1$ and $d_2$ are equivalent, i.e. $\forall x \in X, \epsilon < 0 \exists \delta >0: U_\delta^1 \subset U_\epsilon^2 \land U_\delta^2 \subset U_\epsilon^1 $
2) The convergent sequences in $(X,d_1)$ and $(X,d_2)$ coincide
This question has been asked and answered multiple times, but I still have one particular question. I am not really sure what condition 2 means. The two interpretations I see:
a) $\{(a_n)_{n \ \in \mathbb{N}} : (a_n)_{n \ \in \mathbb{N}} \text{ converges in } (X,d_1) \}$ = $\{(a_n)_{n \ \in \mathbb{N}} : (a_n)_{n \ \in \mathbb{N}} \text{ converges in } (X,d_2) \}$, which would allow a sequence to converge to different points for the different metrics.
b) $\forall a \in X, (a_n)_{n \ \in \mathbb{N}} \subset X: a_n \rightarrow_{d_1} a \Leftrightarrow a_n \rightarrow_{d_2} a$, where a convergent sequence must have the same limit point in both metrics.
I have already done the proof for b), but I could not find a way to prove a). I think that b) is actually wrong, but I would be glad for a reassurance
Best regards!
Max
  • 81
Conditions (a) and (b) are equivalent. Obviously (b) implies (a). One way to see the reverse would be by proving the following:
Lemma. Let $(a_n)$ be a sequence in a metric space. Then $a_n \to a$ if and only if the sequence $(a_1, a, a_2, a, a_3, a, \dots)$ is convergent.
Nate Eldredge
  • 101,664
Conditions a) and b) are equivalent in Hausdorff spaces. More generally, consider a function $f$ from a topological space $X$ to the Hausdorff space $Y$. If every convergent net $(a_i)_{i\in A}\to a$ in $X$ maps to a convergent net in $Y$, then the image net $(f(a_i))_{i\in A}$ indeed converges to the image $f(a)$ of the limit point, thus $f$ is continuous. See $f$ brings convergent nets to convergent nets, is it continuous?. One can show that the same holds if nets are replaced by sequences. So if every convergent sequence $(a_n)_{n\in\mathbb N}\to a$ in $d_1$ is convergent in $d_2$, then it converges to the same point $a$ with respect to $d_2$.
Stefan Hamcke
  • 28,621
