Proof that the power of $2$ in $(3n)!$ is greater than or equals to the power of $2$ in $n!(n+1)!(n+2)!$.
I tried doing some algebraic manipulation, $$ \begin{align} \frac{(3n)!}{n!(n+1)!(n+2)!} &= \binom{3n}{n+2}\frac{(2n-2)!}{(n+1)!n!} \\ &= \binom{3n}{n+2}\binom{n-2}{n+1}\frac{(n-3)!}{n!} \\ &= \binom{3n}{n+2}\binom{2n-2}{n+1}\frac{1}{(n-2)(n-1)n} \end{align} $$
Here, $\binom{3n}{n+2}$ and $\binom{2n-2}{n+1}$ are integers but $\frac{1}{(n-2)(n-1)n}$ is creating problems.
My argument is that some powers of $2$ from $\binom{3n}{n+2}$ and $\binom{2n-2}{n+1}$ would cancel out the powers of $2$ from $\frac{1}{(n-2)(n-1)n}$. But the argument is too ambiguous to be written down as a "proof".
Please let me know if there's a better way to approach these kinds of problems.
Any help would be highly appreciated.
bhache
  • 37
Toshu
  • 1,109
  • 14
  • 30
The claim is true for $n \ge 3$. As observed in the comments above it is false for $n = 1$ and $n = 2$.
We can apply Legendre's Formula in its alternate form for $p=2$:
$$\nu_2(n!)=n-s_2(n)$$
where $\nu_2(n)$ is the exponent of the largest power of $2$ that divides $n$ and $s_2(n)$ is the sum of the digits in the binary representation of $n$.
We will use the following facts for $a$ and $b$ positive integers:
  • $s_2(a+b) \le s_2(a) + s_2(b)$: it can be shown for example using Legendre's formula for $a+b \choose b$: $0 \le \nu_2({a+b \choose b}) = a+b-s_2(a+b)-b +s_2(b)-a+s_2(a)$;
  • $s_2(2a) = s_2(a)$;
  • $s_2(2a+1) = s_2(a)+1$;
  • $(eq. 1)$ $\nu_2((3n)!)-\nu_2(n!)-\nu_2((n+1)!)-\nu_2((n+2)!)=3n-s_2(3n)-n+s_2(n)-n-1+s_2(n+1)-n-2+s_2(n+2)=s_2(n)+s_2(n+1)+s_2(n+2)-3-s_2(3n)$
We divide the problem for $n$ even and odd:
1. $n = 2k+1$, $k \ge 1$
$$s_2(n)=s_2(2k+1)=s_2(k)+1$$ $$s_2(n+1)=s_2(2k+2)=s_2(2(k+1))=s_2(k+1)$$ $$s_2(n+2)=s_2(2k+3)=s_2(2(k+1)+1)=s_2(k+1)+1$$ $$s_2(3n)=s_2(6k+3)=s_2(2(3k+1)+1)=s_2(3k+1)+1=s_2(k+1+2k)+1 \le s_2(k+1)+s_2(2k)+1=s_2(k+1)+s_2(k)+1$$
and putting them together ($(eq. 1)$) it is enough to show that:
$$s_2(k)+2s_2(k+1)+2-3 \ge s_2(k+1) + s_2(k) + 1$$
i.e. $s_2(k+1) \ge 2$, which is true except for $k=2^m-1$, $m \ge 1$. In that case $n=2^{m+1}-1$ and:
$$s_2(n)=m+1$$ $$s_2(n+1)=1$$ $$s_2(n+2)=2$$ $$s_2(3n)=s_2(3 \cdot (2^{m+1}-1))=s_2(2^{m+2}+2^{m+1}-4+1)=s_2(2^{m+2}+4 \cdot (2^{m-1}-1)+ 1)= 1+m-1+1 = m+1$$
and combining them we need to show that:
$$m+4-3 \ge m+1$$
which is true.
2. $n = 2k$, $k \ge 2$
$$s_2(n)=s_2(2k)=s_2(k)$$ $$s_2(n+1)=s_2(2k+1)=s_2(2k)+1=s_2(k)+1$$ $$s_2(n+2)=s_2(2k+2)=s_2(2(k+1))=s_2(k+1)$$ $$s_2(3n)=s_2(6k)=s_2(3k)=s_2(2k+k) \le s_2(2k)+s_2(k) = 2 s_2(k)$$
$$2s_2(k)+1+s_2(k+1)-3 \ge 2s_2(k)$$
i.e. again $s_2(k+1) \ge 2$, which is true except for $k=2^m-1$, $m \ge 2$. In that case $n=2^{m+1}-2$ and:
$$s_2(n)=s_2(2^{m+1}-2)=s_2(2^m-1)=m$$ $$s_2(n+1)=s_2(2^{m+1}-1)=m+1$$ $$s_2(n+2)=s_2(2^{m+1})=1$$ $$s_2(3n)=s_2(3 \cdot (2^{m+1}-2))=s_2(3 \cdot (2^{m}-1))=s_2(2^{m+1}+2^{m}-4+1)=s_2(2^{m+1}+4 \cdot (2^{m-2}-1)+ 1)= 1+m-2+1 = m$$
$$2m+2-3 \ge m$$
i.e.
$$m \ge 1$$
which is true.
See also this linked question.
The largest power of a prime $p$ in $n!$, $\nu_p(n!)$, can be obtained using the Legendre's Formula $$ \nu_p(n!) = \sum_{i=0}^{\infty}\left\lfloor \frac{n}{p^i} \right\rfloor. $$ Thus, $$ \begin{align} \nu_2(3n!) &= \sum_{i=0}^{\infty}\left\lfloor \frac{3n}{2^i} \right\rfloor \\ \nu_2\left(n!(n+1)!(n+2)!\right) &= \sum_{i=0}^{\infty} \left(\left\lfloor \frac{n}{2^i} \right\rfloor + \left\lfloor \frac{n+1}{2^i} \right\rfloor + \left\lfloor \frac{n+2}{2^i} \right\rfloor \right) \quad(\because a^p \cdot a^q = a^{p+a}). \end{align} $$
We then need to examine the validity of $\nu_2(3n!) \ge \nu_2\left(n!(n+1)!(n+2)!\right)$ and the requisite conditions. We have, for $i > 1$ $$ \begin{align} \left\lfloor \frac{3n}{2^i} \right\rfloor &= \left\lfloor \frac{n}{2^i} \right\rfloor + \left\lfloor \frac{n}{2^i} + \frac{1}{3} \right\rfloor + \left\lfloor \frac{n}{2^i} + \frac{2}{3} \right\rfloor & \left(\because \lfloor nx \rfloor = \sum_{i=0}^{n-1} \left\lfloor x + \frac{i}{n} \right\rfloor\right) \\ & \ge \left\lfloor \frac{n}{2^i} \right\rfloor + \left\lfloor \frac{n+1}{2^i} \right\rfloor + \left\lfloor \frac{n+2}{2^i} \right\rfloor & (\because x > y \implies \lfloor x \rfloor > \lfloor y \rfloor). \end{align} $$
Moreover, observe that $\forall n \in \mathbb{N}$, $ \left\lfloor \frac{n}{2} \right\rfloor + \left\lfloor \frac{n+1}{2} \right\rfloor + \left\lfloor \frac{n+2}{2} \right\rfloor - \left\lfloor \frac{3n}{2} \right\rfloor = 1. $ For $$ \begin{align} \left\lfloor \frac{3n}{2} \right\rfloor &= \begin{cases} 3\left\lfloor \frac{n}{2} \right\rfloor & \text{if $n$ is even}, \\ 3\left\lfloor \frac{n}{2} \right\rfloor + 1 & \text{if $n$ is odd}, \end{cases} \\ \left\lfloor \frac{n}{2} \right\rfloor + \left\lfloor \frac{n+1}{2} \right\rfloor + \left\lfloor \frac{n+2}{2} \right\rfloor &= \begin{cases} 3\left\lfloor \frac{n}{2} \right\rfloor + 1 & \text{if $n$ is even}, \\ 3\left\lfloor \frac{n}{2} \right\rfloor + 2 & \text{if $n$ is odd}. \end{cases} \end{align} $$
Thus, for $\nu_2(3n!) \ge \nu_2(n!(n+1)!(n+2)!)$, there should exist $i > 1$ such that $\left\lfloor \frac{3n}{2^i} \right\rfloor = 1$ and $\left\lfloor \frac{n}{2^i} \right\rfloor + \left\lfloor \frac{n+1}{2^i} \right\rfloor + \left\lfloor \frac{n+2}{2^i} \right\rfloor = 0$. Equivalently, for some $i > 1$, we need $1 \le \frac{3n}{2^i} < 2$ and $0 \le \frac{n + 2}{2^i} < 1$. These conditions rule out $n \le 2$. Therefore, for $n \ge 3$, the power of 2 in $3n!$ is greater than or equal to the power of 2 in $n!(n+1)!(n+2)!$.
bhache
  • 37
-1
For $n=1$ it's wrong, but for $n=2$ it's true.
Let $$(3n)!\geq n!(n+1)!(n+2)!$$ for $n\geq2$.
Thus, $$(3n+3)!=(3n+1)(3n+2)(3n+3)(3n)!\geq$$ $$\geq(3n+1)(3n+2)(3n+3)n!(n+1)!(n+2)!\geq(n+1)!(n+2)!(n+3)!,$$ where the last inequality it's $$(3n+1)(3n+2)(3n+3)\geq(n+1)(n+2)(n+3),$$ which is obvious.
Now, use an induction, id est, the following reasoning.
Let $P(n)$ says $(3n)!\geq n!(n+1)!(n+2)!$ for any natural $n\geq2$.
We proved that:
  1. $P(2)$ is true;
  2. For any $n\geq2$ $P(n)\Rightarrow P(n+1)$ is true.
Thus, by the mathematical induction $P(n)$ is true for any $n\geq2$, which we needed to prove.
    @Toshu I added something. See now. – Michael Rozenberg Jan 05 '20 at 08:36
    Nothing in this argument considers the powers of $2$ in the numbers. In fact, we find that $6!=720=2^4\cdot45$ and $2!3!4!=2\cdot6\cdot24=288=2^5\cdot9$, so the claim is false for $n=2$. In general, let $a=2^m\cdot j$ and $b=2^n\cdot k$; proving $a\ge b$ does not prove $m\ge n$. The claim in the OP appears true for $n\ge 3$. – nickgard Jan 05 '20 at 10:02
  • @nickgard $720\geq288,$ which we need. It means $2^{720}\geq 2^{288}.$ – Michael Rozenberg Jan 05 '20 at 10:08
    @MichaelRozenberg Proving $(3n)!\ge n!(n+1)!(n+2)!$ for $n\ge 2$ is trivial. That's not what is being claimed. The claim is that if we write $(3n)!=2^x\cdot j$ and $n!(n+1)!(n+2)!=2^y\cdot k$, with $j,k$ odd, then $x\ge y$. – nickgard Jan 05 '20 at 10:56
    @nickgard Your problem for $n\geq3$ is interesting, but it is also trivial: we need to work with sums of numbers as $\left[\frac{3n}{2^i}\right]$. But why did you down-vote? – Michael Rozenberg Jan 05 '20 at 11:20
  • @nickgard I think so I've understood what happened. Apparently MichaelRozenberg assumed that the question meant $2^{(3n)!} ≥ 2^{n!(n+1)!(n+2)!}$. And I thought that if $(3n)!≥ n!(n+1)!(n+2)!$ then $\frac{(3n)!}{n!(n+1)!(n+2)!}=\binom{(3n)!}{(n+2)!}\binom{(2n-2)!}{(n+1)!}\frac{1}{(n-2)(n-1)n}>1$ so, the number $\binom{(3n)!}{(n+2)!}\binom{(2n-2)!}{(n+1)!}$ must be divisible by $(n-2)(n-1)n$ thus $(3n)!$ having greater power of $2$. This is incorrect because a number being greater than $1$ doesn't mean that it is an integer. – Toshu Jan 05 '20 at 13:01
  • I realized it later. Correct me if I am wrong. – Toshu Jan 05 '20 at 13:04
    @Toshu I think the only thing I can say is that my interpretation differs from Michael Rozenberg's interpretation. In an earlier comment I wrote: "The claim is that if we write $(3n)!=2^x\cdot j$ and $n!(n+1)!(n+2)!=2^y\cdot k$, with $j,k$ odd, then $x\ge y$." Was that a correct interpretation of your question? As to your approach, I think what you have said is correct, but I also think the given fraction is an integer for $n\ge 3$, so it may be a suitable approach if you can show that's true. – nickgard Jan 05 '20 at 13:45
    I politely request that you do not suggest I have made downvotes that I have, in fact, not made. I would very much like to see this question answered correctly. It is a question that is not as simple as it first seems. – nickgard Jan 05 '20 at 15:27
