10
Let $G$ be an open subset of $\mathbb{C}$. Prove that $(\mathbb{C}\cup \{ \infty\})-G$ is connected if and only if every connected component of $G$ is simply connected.
Dimitris
  • 7,190
  • 32
  • 49
  • Intuitively it holds, but I am stuck on both directions. For the straight one if we take a connected component of G, say H, and suppose that it is not simply connected , then $\overline C-H$ is not connected. Thus $\overline C-H$ is written as a union of two closed disjoint nonempty sets K and L. From this we should derive absurdity... – Dimitris Mar 14 '13 at 17:50
  • Would this also hold for higher dimensions? If no, would there be some counterexample? – xxxg Feb 14 '25 at 15:30
  • @xxxg: A torus is not simply connected but its complement in the $3$-dimensional space it is embedded in, is connected. If you really want an open subset, choose a open tubular neighbourhood of it. – Loulou Mar 11 '25 at 21:37
If the connected open set $H \subset \mathbb C$ is not simply connected, there is a simple closed curve $C$ in $H$ that is not homotopic to a point in $H$. Therefore there must be points inside $C$ that is not in $H$. Such a point and $\infty$ are in different connected components of $({\mathbb C} \cup \{\infty\} - G$.
Robert Israel
  • 470,583
