I'm investigating a linear system $(A)x=b$, where $A$ depends on several parameters. It appears that an optimal condition for these parameters is found when $\det(A)=1$. Could someone provide the intuitive meaning of $\det(A)=1$ for linear systems, or some hints in the right direction? Thank you in advance.
Asked
Active
Viewed 59 times
https://math.stackexchange.com/q/668/13658 – Marcus Ritt May 01 '19 at 10:49
Some well-behaved systems have $\lvert\det A\rvert=1$, but that is more of a much weaker consequence of some other things, like special algebraic properties of $A$. – May 01 '19 at 10:52
Do those "optimal parameter matrices" have other properties such as being orthogonal matrices? – David May 01 '19 at 11:58
Actually, $A=\tilde{A}-I$, where $I$ is the identity matrix. Additionaly i see for the "condition" of $A$ as $\kappa(A) = |A| |A^{-1}|$ a minimum at optimal parameters or at least a region of small $\kappa < \kappa_0$. This is sufficient for me, since i can argue with $\kappa < \kappa_0$ for a good conditioned system with respect to optimal parameters. – user284463 May 01 '19 at 12:44
