8
What is the actual inequality that holds for the heat semigroup between fractional Sobolev space $W^{2\alpha,p}$ and classical Lebesgue space $L^q$?
I am trying to derive an inequality $$ \lvert\lvert e^{t\Delta}f \rvert\rvert_{W^{2\alpha,p}} \leq \frac{C}{t^\beta} \lvert\lvert f \rvert\rvert_{L^q} $$ but i cannot manage to find the right value of $\beta$.
I am trying to write the heat semigroup as a convolution $$ e^{t\Delta}f = K_t*f $$ where $K_t$ is the heat kernel, and use Holder inequality for convolutions, but I am stuck when computing $$ \lvert\lvert (I-\Delta)^\alpha K_t \rvert\rvert_{L^r} $$ where $\frac{1}{q}+\frac{1}{r} = \frac{1}{p}+1$.
Any help is appreciated.
Bernard
  • 179,256
This isn't a complete solution/answer, just a couple estimates that may be useful.
I'm going to try to look into this more, but I do know a couple of estimates that may be of help. I considered posting this as a comment, but it seemed a bit long and perhaps poorly suited.
We have the following estimates for $1\leq r \leq p \leq \infty$ and $t>0$: $$\| e^{t\Delta}f\|_{L_x^p} \lesssim \frac{1}{t^{\frac{d}{2}\left(\frac{1}{7}-\frac{1}{p}\right)}}\|f\|_{L_x^r},$$ $$\| e^{t\Delta}\nabla f\|_{L_x^p} \lesssim \frac{1}{t^{\frac{1}{2} + \frac {d}{2}\left(\frac{1}{r}-\frac{1}{p}\right)}}\|f\|_{L_x^r}.$$ I hope you find this useful. I'll continue looking into/thinking about the desired estimate. If it would be of help, I'm happy to post some info on proofs.
Gary Moon
  • 2,555
