Let $u(x,t)$be the solution for the Cauchy Problem
$$u_t-u_{xx} = 0 \mbox{ in $\mathbb{R}\times ]0, \infty[$}$$ $$u(x,0) = u_0(x) \mbox{ in $\mathbb{R}$} $$
where $u_0\in S(\mathbb{R})$(schwartz space in $\mathbb{R})$. Conclude that, for each fixed $t_0>0$, the function $x\to u(x,t_0)$ belongs to the Gevrey class of order $1/2$ in $\mathbb{R}$
I already defined the Gevrey class here: $\sup_K |\partial^{\alpha}u|\le C^{|\alpha|+1}\alpha!^s$ then $u$ is analytic for $s\le 1$ but here is the definition again:
A function $u\in C^{\infty}$ belongs to the Gevrey Class of order $s$ if for every compact $K$ of $\Omega$ there is a constant $C$ such that
$$\sup_K |\partial^{\alpha}u|\le C^{|\alpha|+1}\alpha!^s, \ \alpha\in\mathbb{Z}_+^N$$
this exercise comes after this one:
define, for $x\in\mathbb{R}$,
$$v(x) = \int_{\mathbb{R}}e^{ix\lambda-a\lambda^2}d\lambda$$
Show that $v$ belongs to the Gevrey cass of order $1/2$ in $\mathbb{R}$
So maybe they have something in common. The last exercise above looks like a fourier transform.
UPDATE
$$||\partial_x^n \phi||_{L^2} = (\frac{1}{\sqrt{4\pi t}}\int|\partial_{x}^n| e^{-(x\sqrt{4t})^2}dx)^{1/2} = (\frac{1}{\sqrt{\pi}}\int|\partial_x^n e^{-x^2}|dx)^{1/2} = ||\partial_x^n \phi_{1/4}||L^2$$
