11
From problem 2.3.25 in Topics in Algebra, 2$\varepsilon$ by I. N. Herstein:
Let $G$ be the group of all $2 \times 2$ matrices $\left(\begin{array}{c c}a & b \\ c & d\end{array}\right)$ where $ad-bc \ne 0$ and $a,b,c,d$ are integers modulo 3, relative to matrix multiplication. Show that $o(G) = 48$.
I know that $o(G) \le 3^4 = 81$, since $a,b,c,d$ can each take one of 3 values (mod 3). I attempted to tighten this bound by finding the number of matrices such that $ad=bc$ (mod 3):
  • Suppose $ad=bc=0$ (mod 3). Then ($a = 0$ or $d = 0$) and ($b = 0$ or $c = 0$), leading to 36 possible values for $(a,b,c,d)$.
  • Suppose $ad=bc=1$ (mod 3). Then ($a=d=1$ or $a=d=2$) and ($b=c=1$ or $b=c=2$), leading to 4 possible values for $(a,b,c,d)$.
  • Suppose $ad=bc=2$ (mod 3). Then ($(a,d)=(1,2)$ or $(a,d)=(2,1)$) and ($(b,c)=(1,2)$ or $(b,c)=(2,1)$), leading to 4 possible values for $(a,b,c,d)$.
So, there are in total $36+4+4 = 44$ such $\left(\begin{array}{c c}a & b \\ c & d\end{array}\right)$ where $ad-bc=0$ (mod 3). That means there are at most $81-44 = 37$ such $\left(\begin{array}{c c}a & b \\ c & d\end{array}\right)$ where $ad-bc\ne 0$, i.e., $o(G) \le 37$. However, this contradicts the problem. Where did I go wrong? Can someone set me on the right path?
Red
  • 113
    There are great answers below, but one thing that you might want to try next time for this kind of problem is to make a big table. There are only 81 of them, after all. It's not a proof, but you probably would have seen right away where you missed something. Never underestimate the power of seeing a pattern with your own eyes. – Josephine Moeller Feb 06 '13 at 05:35
6 Answers6
11
Vector $a\choose c$ must be non-zero, this allows $p^2-1$ choices. Vector $b\choose d$ must not be a multiple of $a\choose c$, this allows $p^2-p$ choices. Thus, $|G|=(p^2-1)(p^2-p)$.
  • @eitzen : is it true that number of such matrices from $G$ whose determinant is $1$ is half the order of $G$? i found it true for case $p=3$. – wanderer Feb 06 '13 at 14:10
  • Nice answer! Let me ask you one question: how did you derive $p^2-p$ choices? – RFZ Nov 24 '17 at 08:25
  • @RFZ The second column vector can be a multiple of the first in $p$ different ways in $\mathbb{Z}_{p}$: $0$ times, $1$ time,..., $p-1$ times. – ZSMJ Jun 11 '18 at 17:50
  • Really it's an good idea. Thank you. – Avinash N Sep 21 '19 at 09:29
Use the following result: A matrix is non-singular $\iff$ the columns are linearly indipendent.
Sugata Adhya
  • 4,059
Hints:
(1) In how many ways can you choose the first column for a matrix in $\,G\,$ ?
(2) Now, in how many ways can you choose the second column?
If you know the vector field $\,\Bbb F_3^2=\left(\Bbb Z/3\Bbb Z\right)^2\,$ then $\,G\,$ is the set of all the invertible matrices over this vector space, and the hints above basically ask: how many different (ordered, of course) basis are there for $\,\Bbb F_3^2\,$ over $\,\Bbb F_3\,$ ?
DonAntonio
  • 214,715
There are only $25$ matrices with $ad=bc=0$. To get $ad=0$ you must have $a=0$ ($3$ cases) or $b=0$ ($3$ cases), but two of those $6$ cases are identical ($a=b=0$), so you really have only $5$. After this correction you’re throwing out $25+4+4=33$ matrices, leaving the desired $48$.
Brian M. Scott
  • 631,399
This is known as the general linear group $\text{GL}(n,q)$ where $n$ is the dimension of your matrices, $q$ denotes the Galois field $\text{GF}(q)$. In your case, $G=\text{GL}(2,3)$. There is a general way to count the size of $\text{GL}(n,q)$ by scanning each row of a matrix, roughly speaking.
Easy
  • 4,515
-2
Let G be group of all 2 cross 2 matrices(a b c d){where in 1st row has a and b,2nd row has c and d}and a,b,c,d are integers modulo 3,relative to matrix multiplication.show ghat o(G)=48.(topics in algebra by i n hetstein with 2nd edition.capter-2 problem number 25) Solution:-According to the question this is a general linear group of integers modulo n.for this in general we have a formula to find the order of group. o(GL(n z_p))=(p^n-1)(p^n-p)...(p^n-p^n-1) So according to this formula here n=2 and p=3.Now put these value in the above formula we will get order of general linear equal to 48.
