Question 1
Is there an equation to calculate or approximate the Product of powers of two less than or equal to in general 2n?
Example 1
Given for example 2n = 14 this would simply be $2.4.8=2.2^2.2^3$ easily seen by inspection.
I know one can use Legendre's Theorem (see question https://math.stackexchange.com/a/141197/155629) to do this but that's not what I'm after since it uses the integer function [x]; same with answer below. An approximation would be fine too.
onepound
  • 1,409
  • 10
  • 28
The product will be of the form $2.2^2.2^3\dots2^{m-1}.2^m$ for some $m$, which simplifies to $2^{m(m+1)/2}$. And $m$ is the exponent of the largest power of $2$ that is less than or equal to $2n$ so
$m = \lfloor \log_2 (2n) \rfloor = 1 + \lfloor \log_2 (n) \rfloor$
In the example,
$2n=14$
$n=7$
$m=1+\lfloor 2.807\dots \rfloor=3$
$m(m+1)/2 = 6$
and so the product is $2^6=64$.
gandalf61
  • 15,626
