I want to evaluate $$\int_{0}^{1}{\frac{{{\ln }^{2}}\left( 1-x \right){{\ln }^{2}}\left( 1+x \right)}{1+x}dx}$$ I run this integral on Maple, It does converge. How we get a closed form? Is that related to polylogs? $\operatorname{Li}_{5}\left(\frac{1}{2}\right)$
$$\begin{eqnarray*} \int_{0}^{1}{\frac{{{\ln }^{2}}\left( 1-x \right){{\ln }^{2}}\left( 1+x \right)}{1+x}dx} &=& \left. \left(\frac{\partial^2}{\partial s^2}\frac{\partial^2}{\partial t^2} \int_0^1 dx\, (1-x)^s(1+x)^{t-1} \right) \right|_{s=t=0} \\ &=& \left. \left(\frac{\partial^2}{\partial s^2}\frac{\partial^2}{\partial t^2} \,\frac{{}_2F_1(1-t,1;s+2;-1)}{s+1} \right) \right|_{s=t=0} \end{eqnarray*}$$ Here we've used Euler's integral representation for the hypergeometric function.
Addendum: Using the series representation for the hypergeometric function we can take the derivatives. After a little work we find the integral can be written as $$\sum_{k=2}^\infty \frac{(-1)^k}{k+1} \left(H_k^2 - H_k^{(2)}\right) \left(H_{k+1}^2 + H_{k+1}^{(2)}\right),$$ where $H_k$ and $H_k^{(n)}$ are the harmonic and generalized harmonic numbers, respectively. This sum has bad convergence behavior, the terms go like $(-1)^k(\log k)^4/k$ $(k\to\infty)$. Since the sum is alternating we could accelerate it using the Euler transform, for example.
- 20,221
Thx! But there should be a nicer form : ) – Ryan Dec 28 '12 at 02:36
@Ryan: If it exists someone will post it here. I would be surprised, but I have been before. :-) – user26872 Dec 28 '12 at 03:02
@Chris'ssister : Sure buddy : ) – Ryan Dec 28 '12 at 10:25
@Chris'ssister I m sry guys, Actually one of the integral got a missing lnx term :( You can see here (lots of integral and papers etc) : http://tieba.baidu.com/f?kw=%D2%B5%D3%E0%CA%FD%D1%A7%D1%D0%BE%BF&fr=itb_ofeed – Ryan Jan 30 '13 at 02:29
@oen http://tieba.baidu.com/f?kw=%D2%B5%D3%E0%CA%FD%D1%A7%D1%D0%BE%BF&fr=itb_ofeed No 64 65 got relevant paper~ – Ryan Jan 30 '13 at 02:30
@Ryan: I suggest asking a new question. Cheers! – user26872 Jan 30 '13 at 03:58
The result is $$ -4\operatorname{Li}_5\left(\frac12\right)+4\zeta(3)\log^2(2)-\frac{2\pi^2}9 \log^3(2)-\frac{\pi^2}{3}\zeta(3)-\frac{\pi^4}{20}\log2+\frac7{30}\log^5(2)+ \frac{63}8\zeta(5) =0.418709830998418751408037243448… $$
- 7,654
- 41
3Do you mean:$$-4\operatorname{Li}_5(\frac12)+4\zeta(3)\log^2(2)-\frac{2\pi^2}9 \log^3(2)-\frac{\pi^2}{3}\zeta(3)-\frac{\pi^4}{20}\log2+\frac7{30}\log^5(2)+ \frac{63}8\zeta(5)$$ – Akiva Weinberger Sep 21 '14 at 20:32
Also: That seems to be correct, numerically. How did you get this? – Akiva Weinberger Sep 21 '14 at 20:42
1A derivation of this closed form is given in Cornel's book as problem 1.8 – Robert Lee Jul 29 '23 at 05:49
