29
Given a linear system of equations $A\vec x = \vec b$, if the determinant $\det(A)$ is $0$, then how do we know if the system has no solutions or infinitely many solutions?
Two sub-questions:
a) Using Cramer's Rule, the determinant of $A$ being zero means that a situation of "Division by zero" arises. Then, there being no solution is understandable as division by zero is not defined. But it confuses me how then, in any circumstance, the system can have solutions at all, since the formula in Cramer's rule is undefined. Is there an intuitive and insightful explanation?
b) Given that $\det(A) = 0 $, am I right to think that there are infinitely many solutions if and only if the system of equations is homogeneous, i.e. $\vec b = \vec 0$? Please explain why or why not.
Lorents
  • 325
Ivy Mike
  • 1,177
    A matrix $,A,$ cannot have solutions, finite or infinite. You have to make clear what you mean: do you mean a homogeneous system $,A\vec x=\vec 0,$ , or a non-homogeneous system $,A\vec x=\vec b,,,,,\vec b\neq\vec 0,$ ? – DonAntonio Dec 03 '12 at 12:24
  • @DONANTONIA Sorry,I mean whether the system of equation represented by A has solutions,finite or infinite.Thanks for pointing it out.It's my first question on this forum.And yes, I have mentioned in the first line that I mean non-homogeneous system. – Ivy Mike Dec 03 '12 at 12:26
  • You might want to test your question on simple $2\times2$ systems. – Did Dec 03 '12 at 12:27
  • I mean, like in a homogeneous system of equations,if det(A)=0,then the system has infinite number of solutions else if det(A) is not zero then it has one a unique,but trivial solution.I want to know what happens for the case of non-homogeneous equations.Thanks. – Ivy Mike Dec 03 '12 at 12:30
5 Answers5
22
For any square linear system $\,A\vec x=\vec b\,$ over some field, there exists a unique solution iff $\,\det A\neq 0\,$ , as then we can use the inverse matrix:
$$A\vec x=\vec b\Longleftrightarrow A^{-1}A\vec x=A^{-1}\vec b\Longleftrightarrow A^{-1}\vec b=\vec x $$
As for (a) and your "main question": if $\,\det A=0\,$ one still may have to check whether there are no solutions or infinite solutions (assuming we're working on an infinite field). For example, if the system is homogeneous (over an infinite field) it must have infinite solutions, whereas if the system is non-homogeneous it may have no solutions or several:
$$\begin{cases}x+y=1\\x+y=1\end{cases} \Longleftrightarrow \begin{pmatrix}1&1\\1&1\end{pmatrix}\binom{x}{y}=\binom{1}{1}\longrightarrow\,\,\text{infinite solutions}$$
$$\begin{cases}x+y=1\\x+y=0\end{cases} \Longleftrightarrow \begin{pmatrix}1&1\\1&1\end{pmatrix}\binom{x}{y}=\binom{1}{0}\longrightarrow\,\,\text{no solutions at all}$$
and, of course, in both cases above we have $\,\det A=0\,$
DonAntonio
  • 214,715
  • Thanks Boss!!And please don't mind my clumsy ways.I am totally new to this forum and I'll learn the etiquette soon. – Ivy Mike Dec 03 '12 at 12:48
  • Any time, @IvyMike. We all had to learn. Remember to upvote all the questions you find useful (not necessarily only one), and then eventually choose one as your "accepted answer" – DonAntonio Dec 03 '12 at 12:59
  • Can I say for the non-homogeneous linear system that if $\det A=\det A_x=\det A_y=0$, then the system has infinite solutions?($A_x$ => replace the $x$ coefficients with the constant terms in the determinant $A$) – user42912 Aug 10 '17 at 05:43
12
For the case of a linear system of non-homogeneous equations, you need to consider the augmented matrix and compare its rank to the rank of the coefficient matrix of the system.
There are two cases actually: If the vector b is not in the column space of the matrix A, it will have no solutions. If the b is in the column space of A, and since det(A)=0, then it will have infinitely many solutions. Hoping this can be a good starting point for you.
Let be the system of equations: $$ \left\{ \begin{array}{l} ax+by=e \\ cx+dy=f \end{array} \right. $$ If we multiply the determinant by $x$ and use some properties of determinants we get: $$x\begin{array}{|cc|} a & b \\ c & d \\ \end{array}= \begin{array}{|cc|} ax & b \\ cx & d \\ \end{array} \Rightarrow$$
$$\Rightarrow x\begin{array}{|cc|} a & b \\ c & d \\ \end{array}= \begin{array}{|cc|} e-by & b \\ f-dy & d \\ \end{array} \Rightarrow$$ $$\Rightarrow x\begin{array}{|cc|} a & b \\ c & d \\ \end{array}= \begin{array}{|cc|} e & b \\ f & d \\ \end{array}+ \begin{array}{|cc|} -by & b \\ -dy & d \\ \end{array} \Rightarrow$$ $$ \Rightarrow x\begin{array}{|cc|} a & b \\ c & d \\ \end{array}= \begin{array}{|cc|} e & b \\ f & d \\ \end{array}+ 0 \Rightarrow$$ $$\Rightarrow x\begin{array}{|cc|} a & b \\ c & d \\ \end{array}= \begin{array}{|cc|} e & b \\ f & d \\ \end{array} $$ If we have a system where $\begin{array}{|cc|} a & b \\ c & d \\ \end{array}=0$ and $\begin{array}{|cc|} e & b \\ f & d \\ \end{array}=0$ then $x$ can be any real number.
We can do the same with $y$, but in that case we get: $$\Rightarrow y\begin{array}{|cc|} a & b \\ c & d \\ \end{array}= \begin{array}{|cc|} a & e \\ c & f \\ \end{array} $$ Again if $\begin{array}{|cc|} a & b \\ c & d \\ \end{array}=0$ and $\begin{array}{|cc|} a & e \\ c & f \\ \end{array}=0$, $y$ can assume many values depending on $x$ values or vice versa.
RicardoCruz
  • 3,743
I've got a geometric interpretation:
The $2 \times 2$ matrix $\bf{A}$ transforms a vector $\bf{x}$ in the plane to another vector $\bf{b}$.
If $\text{det }\bf{A}=0$, this transformation is, in fact, a flattening (the geometric interpretation of the determinant is that it is the area produced by the transformation of the unit square):
Any vector will be transformed into a vector which will be aligned along the same line going through the origin, whatever the vector $\bf{x}$.
So, if you have $\bf{}Ax=b$ and $\text{det }\bf{A}=0$:
  • If $\bf{b}$ is aligned along this particular line, you can indeed choose any $\bf{x}$. That is : infinite solution.
  • But if $\bf{b}$ is not aligned along this particular line, it's impossible to find a vector $\bf{x}$: The flattening by $\bf{}A$ always produces a vector aligned along this certain line, so $\bf{b}$ can never be a result of the transformation of $\bf{x}$ by $\bf{}A$.
You can reason the same with homogeneous equation: It's a transformation by $\bf{A}$ of a vector $\bf{x}$ into a single point: the origin $O\,(0,\quad 0)$:
Hence if $\text{det }\bf{A}=0$, that is always true, since the flattening produces vectors aligned along a particular line always going through the origin.
ThePhi
  • 170
