Background Information:
From Walter A Strauss Chapter 2.
Imagine an infinite string with constants $\rho$ and $Y$. Then $\rho u_{tt} = T u _{xx}$ for $-\infty < x < \infty$. From physics we know that the kinetic energy is $\frac{1}{2}m v^2$ which in our case takes the form $KE = \frac{1}{2}\rho \int u_t^{2} dx$. This integral, and the following ones, are evaluated from $-\infty$ to $\infty$. To be sure that the integral converges, we assume that $\phi(x)$ and $\psi(x)$ vanish outside an interval $\{|x|\leq R\}$. As mentioned above, $u(x,t)$ [and therefore $u_t(x,t)$] vanish for $|x| > R + ct$. Differentiating the kinetic energy, we can pass the derivatives under the integral sign to get $$\frac{d KE}{dt} = \rho \int u_t u_{tt} dx$$ Then we substitute the PDE $\rho u_{tt} = T u_{xx}$ and integrate by parts to get $$\frac{d KE}{dt} = T\int u_t u_{xx} dx = T u_t u_x - T \int u_{tx} u_x dx$$ The term, $T u_t u_x$ is evaluated at $x = \pm \infty$ and so it vanishes. But the final term is pure derivative since $u_{tx} u_x (\frac{1}{2} u_x^{2})_{t}$. Therefore, $$\frac{d KE}{dt} = -\frac{d}{dt}\int \frac{1}{2} T u_{x}^{2} dx$$ Let $PE = \frac{1}{2}T\int u_{x}^{2}dx$ and let $E = KE + PE$. Then $d KE/dt = - d PE/dt$ or $dE/dt = 0$. Thus $$E = \frac{1}{2}\int_{-\infty}^{\infty}(\rho u_t^{2} + T u_{x}^{2})dx$$ is a constant independent of $t$. This is the law of conservation of energy.
Question:
Consider an open, bounded region $U$, and the Neumann problem $$\begin{cases} -\Delta u - f \ \ &\text{in} \ U\\ \frac{\partial u}{\partial v} = g \ \ &\text{on} \ \partial U \end{cases}$$ Assume that $f$ and $g$ satisfy the constraint $$-\int_{U}f dx = \int_{\partial U}g dS$$ so that a solution is possible.
a.) Prove that solutions to this problem are unique up to additive constants, using an energy argument.
b.) (Dirichlet's principle for the Neumann problem)
Let $\mathcal{A} = C^{2}(\bar{U})$. Define the energy $$E[w] = \int_{U}\frac{1}{2}|Dw|^2 - fw dx - \int_{\partial U}gw dS$$ for $w\in\mathcal{A}$. Prove that $u\in \mathcal{A}$ is a solution to the Neumann problem if and only if $E[u] = \min_{w\in\mathcal{A}}E[w]$.
Remark: Note that, unlike the Dirichlet boundary problem, the boundary condition is not included in the definition of $\mathcal{A}$. For the $(\Leftarrow)$ direction, you must prove that $u$ satisfies the boundary condition, too.
Attempted proof a.) Assume that we have two solutions $u_1(x)$ and $u_2(x)$. Let $v(x) = u_1(x) - u_2(x)$. Then we have $$\begin{cases}\Delta v(x) = 0 \ \ &\text{for} \ x\in U\\ \frac{\partial v}{\partial n}(x) = 0 \ \ &\text{for} \ x\in \partial U \end{cases} $$ So,
\begin{align*} 0 = -\int_U v \Delta v dx &= -\int_{U} v\cdot div(grad (v))dx\\ &= -\int_{\partial U} (v \cdot grad(v))\cdot n dS + \int_{U} grad(v) \cdot grad(v)dx\\ &= -\int_{\partial U}v \frac{\partial v}{\partial n}dS + \int_{U} |\nabla v|^2 dx\\ &= \int_{U} |\nabla v|^2 dx\\ \end{align*}
So, $\Delta v(x) = 0$ for all $x$ and $v(x) = c$ where $c\in\mathbb{R}$, constant. This implies $u_1 = u_2$ and hence the solution is unique.
I am not sure if the proof for part a.) is correct. I don't know how to start b.) as of yet but I am open to suggestions.
