This is a second order linear differential equation with constant coefficients. In that case, one may use the following ansatz:
$$x=e^{\lambda t}$$
After substitution into the differential equation, this gives the following characteristic equation:
$$\lambda^2-6=0 \tag{1}$$
Evaluating for $\lambda$ gives:
$$\lambda=\pm \sqrt{6}$$
Note that if $x_1(t)$ and $x_2(t)$ are solutions to the differential equation, then so is:
$$x(t)=c_1\cdot x_1(t)+c_2\cdot x_2(t)$$
For any constants $c_1$ and $c_2$. Using the roots of the characteristic equation on $(1)$, we obtain:
$$x(t)=c_1e^{\lambda_1 t}+c_2 e^{\lambda_2 t}$$
Therefore, our general solution is given by:
$$x(t)=c_1e^{-\sqrt{6} t}+c_2 e^{\sqrt{6} t} \tag{2}$$
Can you now use the two conditions to determine the appropriate values of $c_1$ and $c_2$? If not, feel free to ask.
