If $f(x)=g(x)$, then $f'(x)=g'(x)$, is it right?
Assume there is a function $f(x)=m(x)\delta(x)$,where $m(x)$ is any function and $\delta(x)$ is Dirac-δ function. We know that $m(x)\delta(x)=m(0)\delta(x)$, so we have $f(x)=m(0)\delta(x)$.
But why $[m(0)\delta(x)]'\ne[m(x)\delta(x)]'$? $[m(0)\delta(x)]'=m(0)\delta'(x)$, and $[m(x)\delta(x)]'=m'(0)\delta(x)+m(x)\delta'(x)$, and I think it's obviously not equal.
Ian
  • 104,572
  • @RafaelWagner There is still a product rule for the derivative of the product of a distribution and a $C^\infty$ function. See for instance http://users.math.yale.edu/~auel/papers/docs/distalk1.pdf Theorem 13 – Ian Mar 25 '17 at 01:13
  • Why do you think that they are different? Although a care is needed as we have to work with distributions and their derivatives, your computation is essentially justified to give the identity $$ m(0)\delta'(x) = m'(0)\delta(x) + m(x)\delta'(x). $$ In some sense this is simply a complicated way of writing the product rule. – Sangchul Lee Mar 25 '17 at 01:22
    @SangchulLee I think the point is to ask: consider $m(x)=kx+1$. Why, if $m \delta$ only "sees" that $m(0)=1$, can $(m \delta)'$ "see" $m'(0)=k$? – Ian Mar 25 '17 at 01:32
  • @Ian, I guess that this is the point where we have to depart from a naive picture of Dirac delta and move to the distribution theory, where the fact that $m\delta'$ can see both $m(0)$ and $m'(0)$ can be understood as the product rule written in the distribution side. – Sangchul Lee Mar 25 '17 at 01:52
    @SangchulLee I think I have a cleaner explanation that I'm writing up now. It's more about $\delta'$ seeing more than it should be able to see, and the first term canceling that out. – Ian Mar 25 '17 at 01:53
  • @Ian, Sounds nice, I am looking forward to see the explanation. – Sangchul Lee Mar 25 '17 at 01:54
  • Please do not call the Dirac Delta a "function." It is not a function, it is a Generalized Function or Distribution. SEE THIS and THIS. – Mark Viola Mar 25 '17 at 05:22
They are actually the same: $[m\delta]'=m(0)\delta'$ and $[m\delta]'=m'\delta+m\delta'$.
The first equality follows from the definition of the distributional derivative:
$$[m\delta]'(\phi)=-[m\delta](\phi')=-m(0)\phi'(0)=m(0)\delta'(\phi).$$
The second equality follows from the distributional product rule.
How can we reconcile these, when it seems like the first version does not involve $m'(0)$ while the second one does? We notice that the $m\delta'$ term in the second version has its own product rule:
$$[m\delta'](\phi)=\delta'[m\phi]=-m'(0)\phi(0)-m(0)\phi'(0).$$
The first term here serves to cancel out the first term arising in the distributional product rule (the one depending on $m'(0)$). In the end only the second term survives.
Ian
  • 104,572
