I apologize beforehand for the vague title and the length of the description I am using to setup my question; I can't seem to be more concise without sacrificing clarity.
Call a region in the plane "nice" if its intersection with any line consists of a finite number of closed intervals. (Is there an existing term for such a region?). The "size" of any such intersection is, naturally, the sum of the lengths of these intervals.
Consider a nice region R. The "cross section of R along the z-axis" is the (nonnegative) function h given by:
C(t) := size of the cross section of R at the (horizontal) line z = t
Similarly, we can define the cross section of R at an arbitrary line.
Here are a couple of questions with (almost) obvious answers:
Question 1: Given a nonnegative function h, does there exist a nice region whose cross section (along some line) is h?
Answer 1: Yes, always. (easy)
Question 2: Given two nonnegative functions g, h and two lines k, l, does there exist a nice region R whose cross sections along k, l are g, h (respectively)?
Answer 2: Depends. Not hard to come up with examples for both possible answers.
Question 3: Given two nonnegative functions g, h and two lines k, l, what are sufficient (but not overly restrictive) conditions that guarantee the existence of a nice region R with the prescribed cross sections?
Answer 3: I don't know ... please help!
Now consider a similar situation in 3 dimensions. Define a region R to be "nice" if the intersection of any plane with R is (measurable and) of finite area. We can define the cross section of a region R along an arbitrary line analogously to the 2d case.
Question 4: What are sufficient conditions on g,h,k,l that guarantee the existence of a nice region (in 3d) with the prescribed cross sections? What if there are more than two prescribed lines and functions?
Answer 4: I have no idea! This is really the question I'm interested in. Any ideas, suggestions or references would be appreciated.
sitiposit
  • 366
  • Most likely you can define "nice" as compact as each closed interval has an open cover, and thus it would have a finite amount of open covers. – Sentinel135 Mar 12 '17 at 19:01
  • Also I'm not sure Q1) is yes, always. But I am also unsure what you mean by it too. Are you asking that we can find a compact cross section for all non-negative functions, or that given a function I can find a section of it that is compact? The former I can find plenty of examples of no, and some fun ones of "Oh hell no!" For the later yes that is true. – Sentinel135 Mar 12 '17 at 19:24
  • Despite my best efforts to be clear, I might have misled you. I'm trying to avoid consideration of the monstrous sets that typically get mentioned in measure theory. Here is what I had in mind. Given any nonnegative function h, define a function g by $g(t) = \sqrt{h(t)/\pi}$. Then let $R_0$ be the solid bounded by the surface generated by the graph of g as it is revolved around the x-axis. Let $R$ be the result of rotating $R_0$ by 90 degrees in the y-axis. I believe that this answers question 1 in the 3 dimensional case. The 2 dimensional case is even simpler. – sitiposit Mar 12 '17 at 19:54
  • Sorry for taking so long for a response. What happens if we let $h: \mathbb R \to {\vec x \in \mathbb R^n:x_i \geq 0,: \forall i\leq n}$ such that $h$ is bijective? Would this have a "nice" region R? – Sentinel135 Mar 12 '17 at 23:49
  • By a nonnegative function h, I meant $h : \mathbb{R} \to {x \in \mathbb{R} \ | \ x \ge 0}$. – sitiposit Mar 12 '17 at 23:52
  • Alright, then how about $h(t)=0$? Does there exist a line $l$ such that $h \cap l =l$? If so, would it mean that $h$ doesn't have a "nice" region R? – Sentinel135 Mar 13 '17 at 00:18
  • I'm not sure you want $h$ and $g$ to be fully unrestricted here. How do you provide an example for Question 1 if we have a really horrible $h$, for instance $$h=\begin{cases}0 & x\in\mathbb{Q}\ 1 & x\not\in \mathbb{Q}\end{cases}$$ Obviously there is a planar set which has these cross-sections, but I don't see how to make it "nice". – RavenclawPrefect Oct 10 '23 at 00:00
