12
I am taking a course in functional analysis and while reviewing the definition of a metric and various examples, my professor mentioned that one of the reason we care about swapping (possibly equivalent?) metrics is in pde, since a solution to a pde may be very difficult to find in one metric space, but easier in another.
I was hoping the mathstack exchange community might be able to expand on this and maybe provide me with some examples hopefully that I can understand.
Thanks!
operatorerror
  • 29,881
This is really embedded into one of the central questions in PDE, namely well-posedness. The well-posedness of a PDE requires three things: existence of a solution, uniqueness of solutions, and continuous dependence of the solution on the data in the problem. In each of these statements there is actually a crucial missing ingredient: existence in what space and in what sense, uniqueness in what space or collection of functions, and continuity with respect to which metric or topology?
It is in the qualification of the spaces / metrics in these three issues that we encounter your professor's point. Here's a very important example in the theory of elliptic equations.
Let $\Omega \subseteq \mathbb{R}^n$ be bounded and open with a smooth boundary and consider the Poisson problem of finding $u$ such that $$ \begin{cases} -\Delta u =f & \text{in }\Omega \\ u =0 & \text{on }\partial \Omega \end{cases} $$ for a given function $f$ (the data in the problem). Remarkably, it's possible to find explicit examples of functions $f \in C^0(\bar{\Omega})$ such that the above problem does not admit a solution $u \in C^2(\Omega)$, where here the notion of solution is pointwise, i.e. $-\Delta u(x) = f(x)$ for all $x \in \Omega$. Framed in terms of the above discussion, the problem is not well-posed in the space $C^2(\Omega)$ for data in $C^0(\Omega)$.
However, if we switch to a different function space and a different notion of solution, then we can produce a solution for the same $f$ given above. If we work with weak solutions, then we require $u \in H^1_0(\Omega)$ (the $L^2$ Sobolev space of order $1$ with functions vanishing on the boundary), and a solution must satisfy $$ \int_\Omega \nabla u \cdot \nabla v = \int_\Omega f v \text{ for all }v \in H^1_0(\Omega). $$ Within this context it's possible to prove that there exists a unique $u \in H^1_0(\Omega)$ solving the PDE in the above weak sense, and that $u$ depends continuously on $f$ in the $H^1_0$ metric in the sense that $$ \Vert u \Vert_{H^1_0} \le C_1 \Vert f \Vert_{L^2} \le C_2 \Vert f \Vert_{C^0} $$ for some constants $C_1,C_2>0$ that don't depend on $f$. This means that the problem is well-posed in this weak sense, and the key difference is changing our notion of solution and the metric that we use to define the function space for solutions and to "measure" the dependence of solutions on the data.
This is, of course, just one small example. There are many, many more...
Glitch
  • 8,836
  • Thank you for your answer. Can you give some reference for the examples of $f \in C^0(\bar{\Omega})$ such that the Poisson problem doesn't have a solution in $C^2(\Omega)$? – Michał Miśkiewicz Jan 08 '17 at 22:13
  • Sure! You can find a discussion of this on this site. Other places to look are: Problem 4.9 in Gilbarg and Trudinger's book Elliptic Partial Differential Equations of Second Order; the example at the end of Chapter 3 in Han and Lin's Elliptic Partial Differential Equations. – Glitch Jan 08 '17 at 23:09
    this is really an incredible answer. Thank you! – operatorerror Jan 09 '17 at 01:04
  • I don't really know much about PDEs, so I don't actually know what changing the metric means in that context besides what you wrote in your answer, but it's not clear to me why changing your metric space should also involve changing whether you accept weak or strong solutions? Wouldn't it be better to provide an example where only the metric is different and the solution is strong in both? – user541686 Jan 09 '17 at 06:26
9
Here's one perspective, involving the notion of distance on function spaces.
Think of different norms on function spaces as giving us different ways of measuring approximations. The basis for this intuition is that norms measure distance between functions and so they let us know in some sense how good approximations are. Existence theorems whose proofs are ultimately based on considering sequences (in particular, the Riesz representation theorem and its derivatives like Lax-Milgram[1]) are sensitive to the method we use to determine "closeness" of approximations.
Often in searching for weak or strong solutions to PDEs we want to use information about the PDE (such as its order). We incorporate this information by choosing the function space with the best metric as the setting of our study. Once we have an appropriate setting, we can effectively use existence theorems like Riesz or Lax-Milgram to study existence and properties of solutions.)
To make this concrete, let's consider a positive, symmetric unbounded operator $T$ defined on a dense domain $D$ in a Hilbert space $H$. The basic example is the Laplacian $T = \Delta = -\sum\partial_i^2$ defined on compactly supported smooth functions $D = C^\infty_0(\Omega)$ in a two-dimensional bounded domain $\Omega\subset\Bbb{R}^2$, and $H = L^2(\Omega)$.
The equation $\Delta u = f$ is really a question about linear algebra in $H$: "Given $f\in H$, can we find $u\in D$ such that $Tu = f$?" If $T$ were bounded, we'd be able to use the Riesz representation theorem to conclude that a weak solution is indeed an actual solution. However, $T$ is not bounded --- that is, the metric on $H$ is not suitable for finding a solution to the equation.
We can define a new norm on $D$ by setting $\|u\|_T^2 = (u,u) + (Tu,u)$. Since $T$ is symmetric and positive this is in fact an inner product. Take the completion of $D$ with respect to this norm; call it $V.$ In fact the extension of the inclusion map $D\hookrightarrow H$ is a compact embedding. (Compactness is not evident; it follows from delicate PDE estimates and is called the Rellich-Kondrachov theorem. The space $V$ is in this case the Sobolev space $H^1_0(\Omega)$.)
In this new norm where the measurement of distance includes both $L^2$ and the action of $T$, the Riesz representation theorem now guarantees a bounded weak solution operator $S$ to the equation $(Tu,\cdot) = F$ where $F$ is a bounded functional on $V$. It turns out that $H\to V^*$ defined by taking $f$ to $(f,\cdot)$, where $\cdot$ is considered as an element of $H$, is a compact operator. By composing it with the solution operator we have a compact solution operator $H\to V$ which gives solutions to the weak equation.
(Note that I have glossed over many details and possible generalizations, which would comprise the majority of a second graduate class on PDEs. These details can be found in Ch 5-6 of Partial Differential Equations by Evans, or Ch 7-8 of Elliptic Partial Differential Operators of Second Order by Gilbarg and Trudinger. Two of the big questions beyond the scope of this answer: What is the proof of Rellich-Kondrachov? When is a weak solution in fact a strong solution? This latter is known as "elliptic regularity.")
[1] The proof of Riesz (by which I mean $H\leftrightarrow H^*$) relies on choice of a vector in one factor of an orthogonal decomposition of $H$; think about how one would compute this.
Neal
  • 34,012
  • That seems almost magical! So you can verify the existence of a solution on some open subset of $\mathbb{R}^n$ since metrics on $\mathbb{R}^n$ are equivalent by tweaking the metric to bound an operator and satisfy the hypothesis of the Riesz representation theorem? Am I understanding correctly? – operatorerror Jan 09 '17 at 01:08
  • @qbert The "metric" here is not a Riemannian metric on $\Bbb{R}^n$, but a distance metric on a function space. We're really changing how we measure the length of vectors (functions) on the domain of the operator. – Neal Jan 09 '17 at 13:37
  • oh duh that's why the Riesz representation theorem comes into play. thank you! – operatorerror Jan 09 '17 at 15:30
