I'm stuck trying to understand part (ii) of the following question;
Fix a positive real number a > 0 and generate a sequence by setting $x_0 = 1$ and, $$x_n = \dfrac{1}{2}\bigg(x_{n-1}+\frac{a}{x_{n-1}}\bigg),$$ for $n = 1, 2, 3....$
(i) The arithmetic mean - geometric mean inequality says that $(\dfrac{x+y}{2}) \geq \sqrt{xy}$ for all $x, y \geq 0.$ Use this to show $x_n-x_{n+1}\geq0$ for all $n= 1, 2, 3,....$
Answer is just := $x_n=\dfrac{1}{2}(x_{n-1}+\dfrac{a}{x_{n-1}}) \geq \sqrt{x_{n-1}(\frac{a}{x_{n-1}})}=\sqrt{a}$
(ii) Use part (i) to show that $x_n - x_{n+1} \geq0$ for $n= 1, 2, 3...$
Solution = $x_n-x_{n+1} = x_n-\dfrac{1}{2}(x_n+\frac{a}{x_n})=\dfrac{(x_n)^2-a}{2x_n} \geq0.$
The solution tells me that $x_n -\dfrac{(x_n)^2-a}{2x_n} \geq0,$ but I don't understand why this has to be a positive number.
Thanks.
In (i) you show that $x_n\ge\sqrt{a}$ for each $n\in\Bbb Z^+$, so you know that $x_n^2\ge a$ for each $n\in\Bbb Z^+$ and hence that $x_n^2-a\ge 0$ for each $n\in\Bbb Z^+$. That immediately implies that
$$\frac{x_n^2-a}{2x_n}\ge 0$$
for each $n\in\Bbb Z^+$, since you know that each $x_n$ is positive.
Brian M. Scott
  • 631,399
  • Hi, I understand the 2nd term is positive from your explanation, but how do I know that $x_n \geq \frac{(x_n)^2-a}{2x_n}$? Apologies if that information is in your answer, I just can't see it. I'm still new to this analysis stuff. – Ryan Tandy Jan 04 '17 at 22:53
    @Ryan: You don’t need to know that: what you need to know is that $x_n-x_{n+1}\ge 0$, and that’s true because $x_n-x_{n+1}=\frac{x_n^2-a}{2x_n}\ge 0$. – Brian M. Scott Jan 04 '17 at 22:57
From $x_n = \frac{1}{2}(x_{n-1}+\frac{a}{x_{n-1}}) $, we get $x_n^2 = \frac{1}{4}(x_{n-1}^2+2a+\frac{a^2}{x_{n-1}^2}) $, so that $x_n^2 -a = \frac{1}{4}(x_{n-1}^2-2a+\frac{a^2}{x_{n-1}^2}) = \frac{1}{4}(x_{n-1}-\frac{a}{x_{n-1}})^2 = \frac{(x_{n-1}^2-a)^2}{4x_{n-1}^2} $.
In particular, this shows that $x_n^2 > a$ and, if $y_n = x_n^2 -a$, then $y_n =\dfrac{y_{n-1}^2}{4(y_{n-1}+a)} $.
This shows that $y_n \le \frac14\min( y_{n-1}, y_{n-1}^2/a) $ which should help.
Note: None of this is original.
marty cohen
  • 110,450
