I am trying to find the number of solutions to the equation $X^2 = 1$ that could exist in any ring $R$. I am unsure how to approach this question but below is what I came up with:
If the ring is without unity, then there are no solutions. If the ring has $1 = 0$ then there is just one solution, namely $0$. If the ring has $1 \neq 0$ then we can write the equation as $X^2 - 1 = 0$ and factorise to $(X-1)(X+1)=0$. Now $R$ could be a domain, or it could have zero divisors. In the former case, we have two solutions ($1$ and $-1$) and in the latter there could possibly be infinitely many zero divisors of $R$ (e.g. if $R$ = $\mathbb{Z}\times\mathbb{Z}$) so there could be infinitely many solutions to this equation.
I'm not sure the argument or the answer is correct.
wrb98
  • 1,385
Indeed, if $R$ has no zero divisors, there are at most two solutions: $1$ and $-1$ (possibly the same).
If $R$ has infinitely many zero divisors, this does not necessarily imply that there are infinitely many solutions. E.g. for $R=\mathbb Z^2$, there are only four solutions $(\pm1,\pm1)$.
In general, if $P\in\mathbb Z[X]$ is a polynomial and $n_R$ denotes the number of zeroes of $P$ in $R$, then $n_{R\times S}=n_R\cdot n_S$ for any rings $R$ and $S$.
A dull example of a ring with infinitely many solutions would thus be $\mathbb Z^{\mathbb N}$.
Bart Michels
  • 26,985
  • 59
  • 123
  • @DonAntonio As far as I know the infinite number of solutions is of $x^2=-1$. In any ring without zero divisors, the solutions of $x^2=1$ are two, except if the characteristic is $2$, when there's just one. – egreg Dec 17 '16 at 15:19
  • Yes, perhaps I misunderstood the minus one there... – DonAntonio Dec 17 '16 at 15:26
