I need to know if some system of congruences of form:
$$x \equiv a_1 \pmod{b_1}$$ $$\ldots$$ $$x \equiv a_n \pmod{b_n}$$ has a solution and how big this solution could be. I can't assume that b are relatively prime so I can't use Chinese remainder theorem. Any ideas?
Bill Dubuque
  • 282,220
  • Do you know how to deal with the case $n = 2$? If so, you can, if nobody has a better idea, iterate until you either reach the end and have a solution, or find out that no solution exists. – Daniel Fischer Nov 11 '16 at 16:57
  • I don't even need to find the solution. I only want to know if such solution exists and how big it is. – John Cyna Nov 11 '16 at 16:59
A solution exists $\iff \gcd(b_i,b_j)\mid a_i-a_j\,$ for all $\,i\ne j,\,$ i.e. iff they are pairwise solvable. See this answer for a proof.
Any solution is unique mod $m = $ lcm of all moduli, so the least natural solution can be as large as $\,m-1,\,$ e.g. $\, x\equiv -1 \pmod {b_i}\iff x\equiv -1\pmod m\,$ has least solution $\, x = m-1$
Indeed if $\,x'$ and $\,x\,$ are solutions then all $\ b_i\mid x'-x\,$ so $\ m = {\rm lcm}\{b_i\}\mid x'=x,\ $ i.e. $\,x'\equiv x\pmod m.\,$ Conversely $\,x'\equiv x\pmod{m}\,\Rightarrow\,x'\equiv x[\equiv a_i]\pmod{b_i}\,$ by $\,b_i\mid m.$
Bill Dubuque
  • 282,220
Try to find partial solutions $x_1, ..., x_n$ such that $x_i \equiv \delta_{i,j} \pmod{b_j}$ for all $i,j \in [1,n]$ (where $\delta$ is the Kronecker delta function).
You can do so by trying integers in $\text{lcm}_{j\ne i}(a_j)\Bbb Z$
You'll find that $x = \sum_{i=1}^n a_i x_i$ is solution to your system.
Astyx
  • 3,930
