13
I was taking a Math Olympiad test and one of the questions was to calculate the following double integral: $$\int_0^\infty\int_0^\infty\frac{\log|(x+y)(1-xy)|}{(1+x^2)(1+y^2)}\ \mathrm{d}x\ \mathrm{d}y$$ Here, as usual, $\log a$ and $|a|$ are the natural logarithm and absolute value of $a$ respectively.
I'm guessing that you're not supposed to solve it analytically, but rather find some symmetry argument or clever simplification that would make it straightforward. Since I don't even know where to start, any help is welcome.
In case you want to know, this was taken from the 2016 Rio de Janeiro State Math Olympiad, known in Portuguese as OMERJ.
Parcly Taxel
  • 105,904
David
  • 133
    The value of it looks like it's $ \frac{\log 2}{2} \pi^2$. A useful substitution seems to be $x = \tan u, , y = \tan v$ which turn the integral into $ \int_{0}^{\frac{\pi}{2}} \int_{0}^{\frac{\pi}{2}} \log \left(\left(\tan u + \tan v\right) \left| 1 - \tan u \tan v \right| \right),\mathrm{d}u,\mathrm{d}v $. – Sirzh Sep 28 '16 at 22:04
    @Sirzh I reached the same conclusion. With a bit of computation, it essentially boils down to computing the integral $$\int_0^{\pi/2} \log \cos \theta , d\theta = -\frac{\pi}{2}\log 2. $$ – Sangchul Lee Sep 28 '16 at 22:07
By setting $x=\tan u$ and $y=\tan v$ we are left with
$$ I=\iint_{(0,\pi/2)^2}\log\left|(\tan x+\tan y)(1-\tan(x)\tan(y))\right|\,dx\,dy $$ and by translating the variables
$$ I = \iint_{(-\pi/4,\pi/4)^2}\log\left|\frac{2\sin(2x+2y)}{(\sin x+\cos x)^2(\sin y+\cos y)^2}\right|\,dx\,dy $$ so it is enough to exploit the Fourier series of $\log\sin x$, leading to: $$ \iint_{(-\pi/4,\pi/4)}\log\left|\sin(2x+2y)\right|\,dx\,dy = -\frac{\pi^2}{4}\log 2$$ and to: $$ \iint_{(-\pi/4,\pi/4)}\log\left|\sin x+\cos x\right|\,dx\,dy = -\frac{\pi^2}{8}\log 2 $$ to deduce: $$\boxed{ I = \color{red}{\frac{\pi^2\log 2}{2}}.}$$
Jack D'Aurizio
  • 361,689
Here is a solution following @Sirzh's hint. Let
$$ I = \int_{0}^{\infty}\int_{0}^{\infty} \frac{\log|(x+y)(1-xy)|}{(1+x^2)(1+y^2)} \, dxdy $$
and
$$ J = \int_{0}^{\frac{\pi}{2}} \log \cos \theta \, d\theta = -\frac{\pi}{2}\log 2. \tag{1}$$
Applying the substitution $x = \tan u$ and $y = \tan v$ to $I$, we get
\begin{align*} I &= \int_{0}^{\frac{\pi}{2}}\int_{0}^{\frac{\pi}{2}} \log|(\tan u + \tan v)(1 - \tan u \tan v)| \, dudv \\ &= \int_{0}^{\frac{\pi}{2}}\int_{0}^{\frac{\pi}{2}} \log|\sin(u+v)\cos(u+v)| \, dudv - \int_{0}^{\frac{\pi}{2}}\int_{0}^{\frac{\pi}{2}} \log(\cos^2 u \cos ^2 v) \, dudv \tag{2} \\ &= \int_{0}^{\frac{\pi}{2}}\int_{0}^{\frac{\pi}{2}} \log\left|\frac{\sin(2u+2v)}{2}\right| \, dudv - 2\pi J. \\ &= \int_{0}^{\frac{\pi}{2}} \left( \frac{1}{2} \int_{v}^{\pi+v} \log \left| \frac{\sin \theta}{2} \right| \, d\theta \right) dv - 2\pi J \qquad (\theta = 2u+2v) \end{align*}
Now since $\theta \mapsto \log \left| \frac{\sin \theta}{2} \right|$ is $\pi$-periodic, for any $v$ we have
\begin{align*} \frac{1}{2} \int_{v}^{\pi+v} \log \left| \frac{\sin \theta}{2} \right| \, d\theta &= \frac{1}{2} \int_{0}^{\pi} \log \left| \frac{\sin \theta}{2} \right| \, d\theta \\ &= \int_{0}^{\frac{\pi}{2}} \log \left| \frac{\sin \theta}{2} \right| \, d\theta = J - \frac{\pi}{2}\log 2. \end{align*}
Therefore
$$I = \frac{\pi}{2} \left( J - \frac{\pi}{2}\log 2 \right) - 2\pi J = \frac{\pi^2}{2}\log 2.$$
$\text{(1)}$ : You may use the Fourier expansion
$$ \log |\cos\theta| = \Re \log\left(\frac{1+e^{2i\theta}}{2} \right) = -\log 2 + \sum_{n=1}^{\infty} \frac{(-1)^{n-1}}{n} \cos (2n\theta) $$
to compute $J$. Alternatively, one can compute $J$ from the following equation
$$J = \int_{0}^{\frac{\pi}{2}} \log \sin\theta \, d\theta = \int_{0}^{\frac{\pi}{2}} \log \sin(2\theta) \, d\theta = \int_{0}^{\frac{\pi}{2}} \log (2\sin \theta \cos \theta) \, d\theta = \frac{\pi}{2}\log 2 + 2J. $$
$\text{(2)}$ : Apply the addition formula to
$$ (\tan u + \tan v)(1 - \tan u \tan v) = \frac{(\sin u \cos v + \cos u \sin v)(\cos u \cos v - \sin u \sin v)}{\cos^2 u \cos^2 v}. $$
Sangchul Lee
  • 181,930
$\newcommand{\braces}[1]{\left\lbrace\,{#1}\,\right\rbrace} \newcommand{\bracks}[1]{\left\lbrack\,{#1}\,\right\rbrack} \newcommand{\dd}{\mathrm{d}} \newcommand{\ds}[1]{\displaystyle{#1}} \newcommand{\expo}[1]{\,\mathrm{e}^{#1}\,} \newcommand{\ic}{\mathrm{i}} \newcommand{\mc}[1]{\mathcal{#1}} \newcommand{\mrm}[1]{\mathrm{#1}} \newcommand{\pars}[1]{\left(\,{#1}\,\right)} \newcommand{\partiald}[3][]{\frac{\partial^{#1} #2}{\partial #3^{#1}}} \newcommand{\root}[2][]{\,\sqrt[#1]{\,{#2}\,}\,} \newcommand{\totald}[3][]{\frac{\mathrm{d}^{#1} #2}{\mathrm{d} #3^{#1}}} \newcommand{\verts}[1]{\left\vert\,{#1}\,\right\vert}$ \begin{align} &\color{#f00}{\int_{0}^{\infty}\int_{0}^{\infty} {\ln\pars{\bracks{x + y}\verts{1 - xy}} \over \pars{1 + x^{2}}\pars{1 +y^{2}}} \,\dd x\,\dd y}\ =\ \overbrace{\int_{0}^{\infty}\int_{0}^{\infty} {\ln\pars{x} \over \pars{1 + x^{2}}\pars{1 + y^{2}}}\,\dd x\,\dd y}^{\ds{=\ 0}} \\[5mm] +&\ \int_{0}^{\infty}\int_{0}^{\infty} {\ln\pars{1 + y/x} \over \pars{1 + x^{2}}\pars{1 + y^{2}}}\,\dd x\,\dd y + \int_{0}^{\infty}\int_{0}^{\infty} {\ln\pars{\verts{1 - xy}} \over \pars{1 + x^{2}}\pars{1 + y^{2}}}\,\dd x\,\dd y \end{align} In the second integral, in the RHS, lets $\ds{x\ \mapsto\ 1/x}$: \begin{align} &\color{#f00}{\int_{0}^{\infty}\int_{0}^{\infty} {\ln\pars{\bracks{x + y}\verts{1 - xy}} \over \pars{1 + x^{2}}\pars{1 +y^{2}}} \,\dd x\,\dd y} \\[5mm] = &\ \int_{0}^{\infty}\int_{0}^{\infty} {\ln\pars{1 + y/x} \over \pars{1 + x^{2}}\pars{1 + y^{2}}}\,\dd x\,\dd y + \int_{0}^{\infty}\int_{0}^{\infty} {\ln\pars{\verts{1 - y/x}} \over \pars{1 + x^{2}}\pars{1 + y^{2}}}\,\dd x\,\dd y \\[5mm] = &\ \int_{0}^{\infty}{1 \over x^{2} + 1}\int_{0}^{\infty} {\ln\pars{\verts{1 - y^{2}/x^{2}}} \over 1 + y^{2}}\,\dd y\,\dd x \,\,\,\stackrel{y/x\ \mapsto\ y}{=}\,\,\, \int_{0}^{\infty}{x \over x^{2} + 1}\int_{0}^{\infty} {\ln\pars{\verts{1 - y^{2}}} \over 1 + x^{2}y^{2}}\,\dd y\,\dd x \\[5mm] = &\ \int_{0}^{\infty}\ln\pars{\verts{1 - y^{2}}}\ \overbrace{\int_{0}^{\infty} {x \over \pars{x^{2} + 1}\pars{y^{2}x^{2} + 1}}\,\dd x} ^{\ds{\ln\pars{y} \over y^{2} - 1}}\ \,\dd y\ =\ \int_{0}^{\infty}{\ln\pars{\verts{1 - y^{2}}}\ln\pars{y} \over y^{2} - 1}\,\dd y \end{align} Now, we split the integral along $\ds{\pars{0,1}}$ and $\ds{\pars{1,\infty}}$. Later on, we make the substitution $\ds{y \mapsto 1/y}$ in the second integral $\pars{~\mbox{along}\ \pars{1,\infty}~}$: \begin{align} &\color{#f00}{\int_{0}^{\infty}\int_{0}^{\infty} {\ln\pars{\bracks{x + y}\verts{1 - xy}} \over \pars{1 + x^{2}}\pars{1 +y^{2}}} \,\dd x\,\dd y} \\[5mm] = &\ \int_{0}^{1}{\ln\pars{1 - y^{2}}\ln\pars{y} \over y^{2} - 1}\,\dd y + \int_{0}^{1}{\bracks{\ln\pars{1 - y^{2}} - 2\ln\pars{y}}\ln\pars{y} \over y^{2} - 1}\,\dd y \\[5mm] = &\ 2\int_{0}^{1} {\ln\pars{1 - y^{2}}\ln\pars{y} - \ln^{2}\pars{y} \over y^{2} - 1}\,\dd y \,\,\,\stackrel{y^{2}\ \mapsto\ y}{=}\,\,\, 2\int_{0}^{1} {\ln^{2}\pars{y}/4 - \ln\pars{1 - y}\ln\pars{y}/2 \over 1 - y}\,{1 \over 2}\,y^{-1/2}\dd y \\[5mm] = &\ {1 \over 4}\ \underbrace{% \int_{0}^{1}{y^{-1/2}\ln^{2}\pars{y} \over 1 - y}\,\dd y} _{\ds{=\ 14\zeta\pars{3}}}\ -\ {1 \over 2}\ \underbrace{\int_{0}^{1}{y^{-1/2}\ln\pars{y}\ln\pars{1 - y} \over 1 - y}\,\dd y}_{\ds{=\ -\pi^{2}\ln\pars{2} + 7\zeta\pars{3}}}\ =\ \color{#f00}{{1 \over 2}\,\pi^{2}\ln\pars{2}} \end{align}
The last two integrals can be straightforward reduced to derivatives of the Beta Function and evaluated at suitable limits.
Felix Marin
  • 94,079
