I was reading that, when trying to solve something like:
$$\lim_{x\to\infty} f(x)g(x)$$
I can rewrite is as:
$$\lim_{x\to\infty} \frac{f(x)}{\frac{1}{g(x)}}$$
and use L'Hospital's Rule to solve. And, if this doesn't work, I can try using the other function as the denominator:
$$\lim_{x\to\infty} \frac{g(x)}{\frac{1}{f(x)}}$$
So I wondered: are there well-known quotients of functions that don't work in either case and, if so, how do I then solve them?
An example that doesn't submit to this process is:
$$\lim_{x\to\infty} x.x$$
But obviously L'Hospital's Rule would not be necessary in this case.
Functions that have general tendencies to have L'Hopital's not solve anything such as the $e$ function. For example, $$f(x) = \frac{e^{x} - e^{-x}}{e^{-x}+e^{x}}$$ If you were to apply L'Hopital's you would go in a circle of deriving it again and again. Although this problem could be solved with algebra, it still does suit your question.
-1
Usually, $f(x)g(x)$ needs to be converted to a fraction when it is of the indeterminate form: $0\cdot\infty$. Examples:
1) $ \lim \limits_{x\to\infty} x\cdot\sin{\frac{1}{x}}=...=1.$
2) $ \lim \limits_{x\to\infty} x^2\cdot\sin{\frac{1}{x}}=...=\infty.$
3) $ \lim \limits_{x\to\infty} x\cdot\sin{\frac{1}{x^2}}=...=0.$
4) $ \lim \limits_{x\to 0} x\cdot\sin{\frac{1}{x}}=...=0.$ (Note: it is not indeterminate, so there is no need to convert to a fraction).
farruhota
  • 32,168
