$\displaystyle\int\frac{xe^{2x}}{(1+2x)^2}\,dx$
With this particular problem. my approach is to to rewrite the integral as $$\int xe^{2x}\frac{1}{(1+2x)^2}\,dx$$ and then pick a $u$ and a $dv$ and take it from there. The only issue I'm running into is that $xe^{2x}$ appears to me as two functions instead of one. What is a suggestion for this?
wa7d
  • 303
    Hint: There's no real issue with that choice; it's ideal. $;$ We have $u=x {\sf e}^{2x} \implies \operatorname d u = (1+2x){\sf e}^{2x}\operatorname d x$ via the product rule. $;$ Which is rather convenient when coupled with $\operatorname d v=\frac{\operatorname d x}{(1+2x)^2} \implies v = \frac{-1}{2(1+2x)}+c$ – Graham Kemp Jan 29 '16 at 22:41
I would suggest letting $u=xe^{2x}$, since it must be integrated by parts (whereas the derivative is the product rule), and $dv=\frac{1}{(1+2x)^2}dx$.
You can allow a composite of two functions be equal to $u$. That is perfectly valid and often required.
zz20s
  • 6,852
    Don't really know who downvoted and why o.O I just gave you an UP for the simplicity of the answer ^^ –  Jan 29 '16 at 22:43
Make the substitution $1 + 2x = t$ so that $\text{d}x = \frac{\text{d}t}{2}$ so you get:
$$I = \int \frac{(t-1)}{2}\cdot \frac{e^{2\left(\frac{(t-1)}{2}\right)}}{t^2}\frac{\text{d}t}{2}$$
and arranging the terms you easily get:
$$\frac{e^{-1}}{4}\int \frac{e^t}{t} - \frac{e^{t}}{t^2}\ \text{d}t$$
Now the first integral is a Special Function called the Exponential Integral function:
$$\int\frac{e^t}{t}\ \text{d}t = \text{Ei}(t)$$
and the second one can be performed by parts, giving the quite same result:
$$\int \frac{e^t}{t^2}\ \text{d}t = -\frac{e^t}{t} + \text{Ei}(t)$$
Putting together and you see the two Special Functions are cancelled by the minus sign, obtaining in the end the result of the integration in $\text{d}t$:
$$\frac{e^{-1}}{4}\frac{e^{t}}{t} \equiv \frac{e^{t-1}}{4t}$$
coming back to $x$:
$$I = \frac{e^{2x}}{4\cdot(1 + 2x)}$$
More about Exponential Integral
https://en.wikipedia.org/wiki/Exponential_integral
Final Remark
Don't forget about the various $C$ constants you can obtain from each integration, and you can set up them as zero!
  • @zz20s Whoops.. I thought it was just a possibility, not a requirement! –  Jan 29 '16 at 22:43
    No problem at all. +1 for an ingenious solution. It's not a requirement, but since the OP leaved towards parts, I just wanted to make sure you knew! – zz20s Jan 29 '16 at 22:44
  • @zz20s Wow thank you! I should have read more carefully :D –  Jan 29 '16 at 22:45
To use the integration by parts method, we do the following: $$\int \frac{1}{(1+2x)^2}xe^{2x}dx=\int \left (-\frac{1}{2(1+2x)}\right )'xe^{2x}dx \\ =-\frac{1}{2(1+2x)}xe^{2x}+\int \frac{1}{2(1+2x)}(e^{2x}+2xe^{2x})dx \\ =-\frac{1}{2(1+2x)}xe^{2x}+\int \frac{1}{2(1+2x)}(e^{2x}(1+2x))dx \\ =-\frac{1}{2(1+2x)}xe^{2x}+\int \frac{e^{2x}}{2}dx \\ =-\frac{1}{2(1+2x)}xe^{2x}+\frac{e^{2x}}{4}+C \\ =e^{2x}\frac{1+2x-2x}{4(1+2x)}+C\\ =\frac{e^{2x}}{4(1+2x)}+C$$
Mary Star
  • 14,186
  • 15
  • 91
  • 205
