If f is an entire function satisfying f(z+1)=f(z) and f(z+i)=f(z) then f must be constant throughout the complex plane. I would appreciate if someone helps me know how to prove the above statement.
Asked
Active
Viewed 136 times
Restrict to a fundamental domain, use compactness, then Liouville's. – Aug 31 '15 at 01:06
This function is bounded and entire, since is is both 1 and i periodic and continuous. It is therefore constant.
ncmathsadist
- 50,127
This function is 1 and i periodic. Its range is just its image of the square cornered by the $0$, $1$, $i$ and $1 + i$. That square is compact, which gives you a bounded range. Now apply Liouville. – ncmathsadist Aug 31 '15 at 01:39
