54
The context:
I'm going to start working on a project that involves running predefined algorithms (and defining my own) for very big graphs (thousands of nodes). Visualization would also be welcome if possible.
This is a research project and the goal is to produce a prototype that generates/handles biological reaction networks.
Also, I would like to stick to these kind of platforms with "everything but the kitchen-sink" for scientific computing. The reason is, we will need other features like differentiation (symbolic and numeric) during the project.
The question:
So my question is, how complete is sage for graph theory algorithms, when compared to Mathematica (Combinatorica) and Matlab.
    Sage, by nature, has a very active online community. So you could try one of the fora listed here. – Dylan Moreland Mar 12 '12 at 19:36
    I flagged. This is a question specific to Sage. I think you should ask here http://ask.sagemath.org/questions/ –  Mar 12 '12 at 20:24
  • @J.D. Thanks for the input. But I thought maybe the sagemath community would have a natural bias. I was trying to avoid it and find users that had chosen "the other side". – Alexandre Martins Mar 12 '12 at 22:36
  • @DylanMoreland Wow. I saw the video but missed everything after it. Thanks for pointing it out. – Alexandre Martins Mar 12 '12 at 22:40
    @J.D.: Note that the [faq] says: We welcome questions about: [...] Software that mathematicians use, so I don't think this is off-topic. – t.b. Mar 13 '12 at 08:57
Try asking on http://ask.sagemath.org/questions/
In fact, there was already a general question asked there about Sage versus other software, and the top answer said, "If you are doing graph theory or serious number theory, you shouldn't even be asking the question of which package to use." That is, if you're doing graph theory, or serious number theory, Sage is the winner by far. This was comparing Sage to all other computer algebra systems. So, I believe the answer is Sage is the best graph theory program that exists. And, it is getting better all the time.
http://ask.sagemath.org/question/1010/reliability-of-sage-vs-commercial-software
Sage combines together many open source graph theory tools that exist (nauty generator, networkx which contains tons of stuff by itself, cliquer, and more) and also all the things that have been programmed by Sage developers. And, if there is anything you want to be able to do that isn't already programmed, you can program it in Python (or if you need it to be really fast, in cython).
As far as visualization, yes, Sage graphs are extremely good graphics. If you save them to a PDF, you can zoom in as much as you want (I'm not exaggerating) and they will still be crisp, clean graphics. And, there is a graph editor that allows you to draw graphs and move the vertices around and add vertices and edges and things like that. Not to mention, there are many built in graphs.
Oh, and by the way, if Mathematica (or one of many other programs) is installed on the same computer as Sage, you can use the functions from those other programs and get the results in Sage.
Here's a video tutorial on graph theory (second video from top). It gives a lot of detail, and includes all the info on graphics such as saving pdfs and using the graph editor to make nice looking graphs.
http://www.sagemath.org/help-video.html
Here's a real quick tutorial on graph theory in Sage:
http://steinertriples.fr/ncohen/tut/Graphs/
Here are the functions available:
    g.add_cycle
    g.add_edge
    g.add_edges
    g.add_path
    g.add_vertex
    g.add_vertices
    g.adjacency_matrix
    g.all_paths
    g.allow_loops
    g.allow_multiple_edges
    g.allows_loops
    g.allows_multiple_edges
    g.am
    g.antisymmetric
    g.automorphism_group
    g.average_degree
    g.average_distance
    g.bipartite_color
    g.bipartite_sets
    g.blocks_and_cut_vertices
    g.bounded_outdegree_orientation
    g.breadth_first_search
    g.canonical_label
    g.cartesian_product
    g.categorical_product
    g.category
    g.center
    g.centrality_betweenness
    g.centrality_closeness
    g.centrality_degree
    g.characteristic_polynomial
    g.charpoly
    g.check_embedding_validity
    g.check_pos_validity
    g.chromatic_number
    g.chromatic_polynomial
    g.clear
    g.clique_complex
    g.clique_maximum
    g.clique_number
    g.cliques
    g.cliques_containing_vertex
    g.cliques_get_clique_bipartite
    g.cliques_get_max_clique_graph
    g.cliques_maximal
    g.cliques_maximum
    g.cliques_number_of
    g.cliques_vertex_clique_number
    g.cluster_transitivity
    g.cluster_triangles
    g.clustering_average
    g.clustering_coeff
    g.coarsest_equitable_refinement
    g.coloring
    g.complement
    g.connected_component_containing_vertex
    g.connected_components
    g.connected_components_number
    g.connected_components_subgraphs
    g.convexity_properties
    g.copy
    g.cores
    g.cycle_basis
    g.db
    g.degree
    g.degree_constrained_subgraph
    g.degree_histogram
    g.degree_iterator
    g.degree_sequence
    g.degree_to_cell
    g.delete_edge
    g.delete_edges
    g.delete_multiedge
    g.delete_vertex
    g.delete_vertices
    g.density
    g.depth_first_search
    g.diameter
    g.disjoint_routed_paths
    g.disjoint_union
    g.disjunctive_product
    g.distance
    g.distance_all_pairs
    g.distance_graph
    g.dominating_set
    g.dump
    g.dumps
    g.eccentricity
    g.edge_boundary
    g.edge_connectivity
    g.edge_cut
    g.edge_disjoint_paths
    g.edge_disjoint_spanning_trees
    g.edge_iterator
    g.edge_label
    g.edge_labels
    g.edges
    g.edges_incident
    g.eigenspaces
    g.eigenvectors
    g.eulerian_circuit
    g.eulerian_orientation
    g.flow
    g.fractional_chromatic_index
    g.genus
    g.get_boundary
    g.get_embedding
    g.get_pos
    g.get_vertex
    g.get_vertices
    g.girth
    g.gomory_hu_tree
    g.graph6_string
    g.graphics_array_defaults
    g.graphplot
    g.graphviz_string
    g.graphviz_to_file_named
    g.hamiltonian_cycle
    g.has_edge
    g.has_loops
    g.has_multiple_edges
    g.has_vertex
    g.incidence_matrix
    g.independent_set
    g.independent_set_of_representatives
    g.interior_paths
    g.is_bipartite
    g.is_chordal
    g.is_circular_planar
    g.is_clique
    g.is_connected
    g.is_directed
    g.is_drawn_free_of_edge_crossings
    g.is_equitable
    g.is_eulerian
    g.is_even_hole_free
    g.is_forest
    g.is_gallai_tree
    g.is_hamiltonian
    g.is_independent_set
    g.is_interval
    g.is_isomorphic
    g.is_line_graph
    g.is_odd_hole_free
    g.is_overfull
    g.is_perfect
    g.is_planar
    g.is_prime
    g.is_regular
    g.is_split
    g.is_subgraph
    g.is_transitively_reduced
    g.is_tree
    g.is_triangle_free
    g.is_vertex_transitive
    g.kirchhoff_matrix
    g.laplacian_matrix
    g.latex_options
    g.layout
    g.layout_circular
    g.layout_default
    g.layout_extend_randomly
    g.layout_graphviz
    g.layout_planar
    g.layout_ranked
    g.layout_spring
    g.layout_tree
    g.lex_BFS
    g.lexicographic_product
    g.line_graph
    g.longest_path
    g.loop_edges
    g.loop_vertices
    g.loops
    g.matching
    g.matching_polynomial
    g.max_cut
    g.maximum_average_degree
    g.merge_vertices
    g.min_spanning_tree
    g.minimum_outdegree_orientation
    g.minor
    g.modular_decomposition
    g.multicommodity_flow
    g.multiple_edges
    g.multiway_cut
    g.name
    g.neighbor_iterator
    g.neighbors
    g.networkx_graph
    g.num_edges
    g.num_verts
    g.number_of_loops
    g.order
    g.periphery
    g.plot
    g.plot3d
    g.radius
    g.random_edge
    g.random_subgraph
    g.random_vertex
    g.relabel
    g.remove_loops
    g.remove_multiple_edges
    g.rename
    g.reset_name
    g.save
    g.set_boundary
    g.set_edge_label
    g.set_embedding
    g.set_latex_options
    g.set_planar_positions
    g.set_pos
    g.set_vertex
    g.set_vertices
    g.shortest_path
    g.shortest_path_all_pairs
    g.shortest_path_length
    g.shortest_path_lengths
    g.shortest_paths
    g.show
    g.show3d
    g.size
    g.spanning_trees_count
    g.sparse6_string
    g.spectrum
    g.steiner_tree
    g.strong_orientation
    g.strong_product
    g.subdivide_edge
    g.subdivide_edges
    g.subgraph
    g.subgraph_search
    g.subgraph_search_count
    g.subgraph_search_iterator
    g.szeged_index
    g.tensor_product
    g.to_directed
    g.to_simple
    g.to_undirected
    g.topological_minor
    g.trace_faces
    g.transitive_closure
    g.transitive_reduction
    g.traveling_salesman_problem
    g.two_factor_petersen
    g.union
    g.version
    g.vertex_boundary
    g.vertex_connectivity
    g.vertex_cover
    g.vertex_cut
    g.vertex_disjoint_paths
    g.vertex_iterator
    g.vertices
    g.weighted
    g.weighted_adjacency_matrix
    g.wiener_index
    g.write_to_eps
And here are some graphs you can easily generate:
graphs.BalancedTree
graphs.BarbellGraph
graphs.BidiakisCube
graphs.BrinkmannGraph
graphs.BubbleSortGraph
graphs.BuckyBall
graphs.BullGraph
graphs.ButterflyGraph
graphs.ChvatalGraph
graphs.CirculantGraph
graphs.CircularLadderGraph
graphs.ClawGraph
graphs.CompleteBipartiteGraph
graphs.CompleteGraph
graphs.CompleteMultipartiteGraph
graphs.CubeGraph
graphs.CycleGraph
graphs.DegreeSequence
graphs.DegreeSequenceBipartite
graphs.DegreeSequenceConfigurationModel
graphs.DegreeSequenceExpected
graphs.DegreeSequenceTree
graphs.DesarguesGraph
graphs.DiamondGraph
graphs.DodecahedralGraph
graphs.DorogovtsevGoltsevMendesGraph
graphs.DurerGraph
graphs.DyckGraph
graphs.EmptyGraph
graphs.ErreraGraph
graphs.FibonacciTree
graphs.FlowerSnark
graphs.FranklinGraph
graphs.FriendshipGraph
graphs.FruchtGraph
graphs.FuzzyBallGraph
graphs.GeneralizedPetersenGraph
graphs.GoldnerHararyGraph
graphs.Grid2dGraph
graphs.GridGraph
graphs.GrotzschGraph
graphs.HanoiTowerGraph
graphs.HeawoodGraph
graphs.HerschelGraph
graphs.HexahedralGraph
graphs.HigmanSimsGraph
graphs.HoffmanSingletonGraph
graphs.HouseGraph
graphs.HouseXGraph
graphs.HyperStarGraph
graphs.IcosahedralGraph
graphs.IntervalGraph
graphs.KneserGraph
graphs.KrackhardtKiteGraph
graphs.LCFGraph
graphs.LadderGraph
graphs.LollipopGraph
graphs.MoebiusKantorGraph
graphs.MoserSpindle
graphs.MycielskiGraph
graphs.MycielskiStep
graphs.NKStarGraph
graphs.NStarGraph
graphs.OctahedralGraph
graphs.OddGraph
graphs.PappusGraph
graphs.PathGraph
graphs.PetersenGraph
graphs.RandomBarabasiAlbert
graphs.RandomBipartite
graphs.RandomGNM
graphs.RandomGNP
graphs.RandomHolmeKim
graphs.RandomInterval
graphs.RandomLobster
graphs.RandomNewmanWattsStrogatz
graphs.RandomRegular
graphs.RandomShell
graphs.RandomTree
graphs.RandomTreePowerlaw
graphs.ShrikhandeGraph
graphs.StarGraph
graphs.TetrahedralGraph
graphs.ThomsenGraph
graphs.ToroidalGrid2dGraph
graphs.WheelGraph
graphs.WorldMap
graphs.cospectral_graphs
graphs.line_graph_forbidden_subgraphs
graphs.nauty_geng
graphs.trees
GeoffDS
  • 11,410
    Thanks for the "to the point " answer. I actually looked for something in ask.sagemath.org but missed the question you linked to. And, loved the nickname. ;) – Alexandre Martins Mar 12 '12 at 22:18
