Is there any way to calculate the multiplicative group of the units of power series ring $k[[x]]$, where $k$ is a field ?
2The units in $k[[x]]$ are precisely those power series whose constant term is a unit. I hope this helps. – Chris Leary Feb 29 '12 at 03:29
Hint $\rm\displaystyle\quad 1\: =\: (a-xf)(b-xg)\ \Rightarrow\ \color{#c00}{ab=\bf 1}\ $ so scaling top & bottom below by $\rm \,b\,$ yields
$$\Rightarrow\ \ \displaystyle\rm\ \ \frac{1}{a-xf}\ =\ \frac{b}{\color{#c00}{\bf 1}-bxf}\ =\ b\:(1+bxf+(bxf)^2+(bxf)^3+\:\cdots\:)$$
- 282,220
1I still cannot see what to do next? how do you prove that the group of units are indeed power series with no-zero constant term? – Kran Jan 21 '17 at 21:13
The multiplicative group is $k[[x]]\backslash (x)$. Certainly those elements divisible by $x$ are not units. If an element is not divisble by $x$ (in other words, has nonzero constant term), you can construct the inverse term by term.
- 10,085
It's possible to be much more specific about the structure of the unit group than has been done so far, as follows. So far we know that the units in $k[[x]]$ are those formal power series with nonzero constant term. Dividing by the constant term shows that this group is isomorphic to $k^{\times}$ (the constant term part) times the group of formal power series $1 + a_1 x + a_2 x^2 + \dots$ with constant term $1$.
Claim: If $k$ has characteristic $0$, then this group is isomorphic to $(k[[x]], +)$. In particular, it is a $\mathbb{Q}$-vector space.
(Note that this can't be true in characteristic $p$ since the group of units is not $p$-torsion: we have, for example, $(1 + x)^p = 1 + x^p \neq 1$.)
The isomorphism is given by the "exponential" map
$$k[[x]] \ni f \mapsto (1 + x)^f \in k[[x]]^{\times}.$$
This is defined using the identity
$$1 + x = \exp \log (1 + x) = \exp \sum_{n \ge 1} (-1)^{n-1} \frac{x^n}{n}$$
(which is where we need that $k$ has characteristic $0$), which allows us to define
$$(1 + x)^f = \exp f \log (1 + x)$$
as a formal power series. This has all of the standard properties of the exponential, and is in particular a homomorphism. The inverse of this isomorphism is the "logarithm" map
$$\log_{1 + x}(g) = \frac{\log g}{\log (1 + x)}$$
where $g$ has constant term $1$. It's formal to verify that these two operations are inverse to each other.
The answer is more interesting in positive characteristic: we get the underlying abelian group of the ring of Witt vectors $W(k)$. For example, when $k = \mathbb{F}_p$ this group is related to the group of $p$-adic integers $\mathbb{Z}_p$, and in fact there is a natural exponential $(1 + x)^f \in \mathbb{F}_p[[x]]$ where $f \in \mathbb{Z}_p$. Edit: See the comments!
- 468,795
I think the unit group of $\mathbb F_p[[X]]$ is isomorphic to $\mathbb F_p^\times\oplus\mathbb Z_p^{(\mathbb N)}$, where $\mathbb Z_p^{(\mathbb N)}$ denotes a countable direct sum of copies of the $p$-adic integers $\mathbb Z_p$. – user26857 Feb 28 '16 at 10:16
2Just passing through and I noticed this answer. I think that Qiaochu's comment about the char p setting is inaccurate -- if $k=\mathbb{F}_p$ then the group is much much bigger than $\mathbb{Z}_p$ -- for example $(1+Xk[[X]]) / (1+X^Nk[[X]])$ is a finite $p$-group which is very far from being cyclic in general, and this sort of argument even shows that $1+Xk[[X]]$ is not finitely-generated. But I don't think @user26857's suggestion is right either -- as $1+Xk[[X]]$ is compact if $k$ is finite, whereas their suggestion does not seem to be (at least if I am interpreting it correctly). – Kevin Buzzard May 05 '17 at 14:52
2I think that the unit group of $\mathbb{F}_p[[X]]$ is isomorphic to $\mathbb{F}_p^\times$ direct sum a countably infinite product (not sum) of $\mathbb{Z}_p$'s, but this comment box is too small for me to fit the proof in. – Kevin Buzzard May 08 '17 at 11:43
1@KevinBuzzard is quite right: the units of $\Bbb F_p[[x]]$ that are $\equiv1\pmod x$ are a direct product of $\Bbb Z_p$’s, the indexing set being the positive integers prime to $p$. – Lubin Jun 04 '18 at 16:09
Does anyone know a reference for Kevin Buzzard's assertion that $\mathbb F_p[[x]]^\times\cong \mathbb F_p^\times\times\prod_{\mathbb N}\mathbb Z_p$? (The source indicated by Watson is no longer accessible.) – Peter Kropholler Jul 26 '23 at 08:22
@PeterKropholler: https://web.archive.org/web/20220526205303/https://www.math.arizona.edu/~ura-reports/063/McMurdie.Christopher/Final.pdf – Drew Nov 28 '23 at 09:02
