From Wikipedia
Formal systems in mathematics consist of the following elements:
- A finite set of symbols (i.e. the alphabet), that can be used for constructing formulas (i.e. finite strings of symbols).
- A grammar, which tells how well-formed formulas (abbreviated wff) are constructed out of the symbols in the alphabet. It is usually
required that there be a decision procedure for deciding whether a
formula is well formed or not.- A set of axioms or axiom schemata: each axiom must be a wff.
- A set of inference rules.
I was wondering if "inference rules" of a formal system means inference rules of a logic system? If yes, is a formal system therefore also a logic system?
But a logic system is just an example or a model of a formal system by an interpretation mapping to $\{ true, false\}$, isn't it? From the last link
A logical system or, for short, logic, is a formal system together with a form of semantics, usually in the form of model-theoretic interpretation, which assigns truth values to sentences of the formal language, that is, formulae that contain no free variables. A logic is sound if all sentences that can be derived are true in the interpretation, and complete if, conversely, all true sentences can be derived.
Thanks and regards!
0by01, and every1by11. – Arturo Magidin Feb 16 '12 at 21:58
