14
How do I evaluate the limit of the following sequence $$a_n = \left(\left( 1 + \frac1n \right) \left( 1 + \frac2n \right)\cdots\left( 1 + \frac nn \right) \right)^{1/n}$$
I tried to take log and then using cauchy $1^{st}$ theorem of limits but I coudn't do it.
Could someone kindly help?
godonichia
  • 2,259
  • 25
  • 47
Consider that $\ln a_n$ is a sequence of Riemann sums for the function $f(x) = \ln(1 + x)$ over the interval $[0,1]$. Thus $$\lim_{n \to \infty} \ln a_n = \int_0^1 \ln(1 + x)\, dx = (1 + x)\ln(1 + x) - (1 + x)|_{x = 0}^1 = 2\ln(2) - 1$$ Now you can find $\lim_{n \to \infty} a_n$ by exponentiation.
kobe
  • 43,217
9
Rewrite $\displaystyle a_n = \prod\limits_{k=1}^{n} \left(1+\frac{k}{n}\right)^{1/n} $
Since, $\displaystyle \lim\limits_{n\to \infty} b_n^{1/n} = \lim\limits_{n\to \infty} \frac{b_{n+1}}{b_n}$ (that is if the limit exists)
We may write:
$\displaystyle \begin{align} \lim\limits_{n\to \infty} a_n =\lim\limits_{n\to \infty} \frac{\prod\limits_{k=1}^{n+1} \left(1+\frac{k}{n+1}\right)}{\prod\limits_{k=1}^{n} \left(1+\frac{k}{n}\right)} &= \lim\limits_{n \to \infty} \frac{\prod\limits_{k=1}^{n+1} (n+k+1)}{\prod\limits_{k=1}^{n} (n+k)}.\frac{(n+1)^{-(n+1)}}{n^{-n}} \tag{1}\\ &=\lim\limits_{n\to \infty} \frac{(n+2)\cdots(2n+2)}{(n+1)\cdots(2n)}.\frac{\left(1+\frac{1}{n}\right)^{-n}}{n+1} \tag{2}\\&= \lim\limits_{n\to \infty} 2(2n+1).\frac{\left(1+\frac{1}{n}\right)^{-n}}{n+1} \tag{3} \\&= \frac{4}{e}\end{align}$
2nd Approach:
Write $\displaystyle a_n = \left(\binom{2n}{n}\frac{n!}{n^n}\right)^{1/n}$
Using the identity $\displaystyle \sum\limits_{k=0}^{n} \binom{n}{k}^2 = \binom{2n}{n}$ we make an application of Cauchy-Schwarz Ineqality
$$\displaystyle (n+1)\binom{2n}{n} = \left(\sum\limits_{k=0}^{n} 1^2\right)\left(\sum\limits_{k=0}^{n} \binom{n}{k}^2\right) \ge \left(\sum\limits_{k=0}^{n} \binom{n}{k}\right)^2 = 4^n$$
Thus, $\displaystyle \frac{4^n}{n+1} \le \binom{2n}{n} \le 4^n \implies \lim\limits_{n \to \infty} \frac{4}{\sqrt[n]{n+1}} = \lim\limits_{n \to \infty} \binom{2n}{n}^{1/n} = 4$ (form, squeeze theorem).
Since, $\displaystyle \lim\limits_{n \to \infty} \frac{(n!)^{1/n}}{n} = e^{-1}$ we get $\displaystyle \lim\limits_{n \to \infty} a_n = \frac{4}{e}$
r9m
  • 18,208
  • Can you please elaborate bit more about last step – godonichia Dec 16 '14 at 20:39
  • @godonichia in the last step I used $\lim\limits_{n\to \infty} \left(1+\frac{1}{n}\right)^{n} = e$. – r9m Dec 16 '14 at 20:40
  • No from 4th last to 3rd last – godonichia Dec 16 '14 at 20:49
  • @godonichia I edited ! if its not clear yet please indicate which line I need to elaborate on ! :) – r9m Dec 16 '14 at 20:58
  • In 1st step from where did the term after product came from – godonichia Dec 16 '14 at 21:03
  • @godonichia those are the denominators in the product $\prod\limits_{k=1}^{n+1} \frac{n+k+1}{n+1}$ and $\prod\limits_{k=1}^{n} \frac{n+k}{n}$ .. there are $n+1$-terms in the numerator product thus $(n+1)^{-(n+1)}$ and $n$-terms in the denominator product hence $n^{-n}$ – r9m Dec 16 '14 at 21:06
  • @godonichia welcome :) I added another approach ! ^^ – r9m Dec 16 '14 at 21:22
