I am trying to find the working of dataframe.columns.difference() but couldn't find a satisfactory explanation about it. Can anyone explain the working of this method in detail?
The function dataframe.columns.difference() gives you complement of the values that you provide as argument. It can be used to create a new dataframe from an existing dataframe with exclusion of some columns. Let us look through an example:
In [2]: import pandas as pd
In [3]: import numpy as np
In [4]: df = pd.DataFrame(np.random.randn(5, 4), columns=list('ABCD'))
In [5]: df
Out[5]:
A B C D
0 -1.023134 -0.130241 -0.675639 -0.985182
1 0.270465 -1.099458 -1.114871 3.203371
2 -0.340572 0.913594 -0.387428 0.867702
3 -0.487784 0.465429 -1.344002 1.216967
4 1.433862 -0.172795 -1.656147 0.061359
In [6]: df_new = df[df.columns.difference(['B', 'D'])]
In [7]: df_new
Out[7]:
A C
0 -1.023134 -0.675639
1 0.270465 -1.114871
2 -0.340572 -0.387428
3 -0.487784 -1.344002
4 1.433862 -1.656147
The function returns as output a new list of columns from the existing columns excluding the ones given as arguments. You can also check it:
In [8]: df.columns.difference(['B', 'D'])
Out[8]: Index(['A', 'C'], dtype='object')
I suggest you to take a look at the official documentation here.
- 2,303
- 2
- 14
- 23
See below an example using dataframe.columns.difference() on 'employee attrition' dataset. Here we want to separate categorical columns from numerical columns to perform feature engineering.
# Empty list to store columns with categorical data
categorical = []
for col, value in attrition.iteritems():
if value.dtype == 'object':
categorical.append(col)
Store the numerical columns in a list
numerical = attrition.columns.difference(categorical)
Notice that the columns.difference() method returns the complement of the passed argument, in this case the numerical columns.
- 127
- 7
