I have a model with 2 categorical outputs.
The first output layer can predict 2 classes: [0, 1]
and the second output layer can predict 3 classes: [0, 1, 2].
How can I apply different class weight dictionaries for each of the outputs?
For example, how could I apply the dictionary {0: 1, 1: 10} to the first output,
and {0: 5, 1: 1, 2: 10} to the second output?
I've tried to use the following class weights dictionary
weight_class={'output1': {0: 1, 1: 10}, 'output2': {0: 5, 1: 1, 2: 10}}
But the code fails with an error.
My script also runs normally when i remove the class_weight parameter
Code Example
I've created a minimal example that reproduces the error
from tensorflow.python.keras.models import Model
from tensorflow.python.keras.layers import Input, Dense
from tensorflow.python.data import Dataset
import tensorflow as tf
import numpy as np
def preprocess_sample(features, labels):
label1, label2 = labels
label1 = tf.one_hot(label1, 2)
label2 = tf.one_hot(label2, 3)
return features, (label1, label2)
batch_size = 32
num_samples = 1000
num_features = 10
features = np.random.rand(num_samples, num_features)
labels1 = np.random.randint(2, size=num_samples)
labels2 = np.random.randint(3, size=num_samples)
train = Dataset.from_tensor_slices((features, (labels1, labels2))).map(preprocess_sample).batch(batch_size).repeat()
# Model
inputs = Input(shape=(num_features, ))
output1 = Dense(2, activation='softmax', name='output1')(inputs)
output2 = Dense(3, activation='softmax', name='output2')(inputs)
model = Model(inputs, [output1, output2])
model.compile(loss='categorical_crossentropy', optimizer='adam')
class_weights = {'output1': {0: 1, 1: 10}, 'output2': {0: 5, 1: 1, 2: 10}}
model.fit(train, epochs=10, steps_per_epoch=num_samples // batch_size,
# class_weight=class_weights
This code runs successfully without the class_weight parameter.
But when you add the class_weight parameter by uncommenting the line
# class_weight=class_weights than the script fails with the following error:
Traceback (most recent call last):
File "test.py", line 35, in <module>
File "venv/lib/python3.6/site-packages/tensorflow/python/keras/engine/training.py", line 1536, in fit
validation_split=validation_split)
File "venv/lib/python3.6/site-packages/tensorflow/python/keras/engine/training.py", line 992, in _standardize_user_data
class_weight, batch_size)
File "venv/lib/python3.6/site-packages/tensorflow/python/keras/engine/training.py", line 1165, in _standardize_weights
feed_sample_weight_modes)
File "venv/lib/python3.6/site-packages/tensorflow/python/keras/engine/training.py", line 1164, in <listcomp>
for (ref, sw, cw, mode) in zip(y, sample_weights, class_weights,
File "venv/lib/python3.6/site-packages/tensorflow/python/keras/engine/training_utils.py", line 717, in standardize_weights
y_classes = np.argmax(y, axis=1)
File "venv/lib/python3.6/site-packages/numpy/core/fromnumeric.py", line 1004, in argmax
return _wrapfunc(a, 'argmax', axis=axis, out=out)
File "venv/lib/python3.6/site-packages/numpy/core/fromnumeric.py", line 62, in _wrapfunc
return _wrapit(obj, method, *args, **kwds)
File "venv/lib/python3.6/site-packages/numpy/core/fromnumeric.py", line 42, in _wrapit
result = getattr(asarray(obj), method)(*args, **kwds)
numpy.core._internal.AxisError: axis 1 is out of bounds for array of dimension 1
Edit
I've also opened an issue in the Keras github page, but i wanted to ask the same question here to see if perhaps i'm missing something and doing something wrong.
