I know that the first degree of the polynomial equation is considered as a linear function.
But, I found some things confusing in linear regression.
1. f(x)= w1 x1+ w2 x2 + W3 x3 --> linear function
2. f(x)= w1 x1+ w2 x2 + W3 x1 x3 --> is it linear? if not, then why?
3. f(x)= w1 x1+ w2 x2 + W3 W4 x3 --> is it linear? if not, then why?
4. f(x)= w1 x1+ w2 x2 + W3 x3 x3 --> it is not linear.
Please help.
A function $x = (x_1, \dots, x_n) \mapsto f(x_1, \dots, x_n) \in \mathbb{R}$ is linear if and only if for every $a,b \in \mathbb{R}$ it holds that $f(a (x_1, \dots, x_n) + b (\xi_1, \dots, \xi_n)) = a f(x_1, \dots, x_n) + b f(\xi_1, \dots,\xi_n)$.
In your second example try computing $f(a x + b \xi)$ to see that the last term $w_3 x_1 x_3$ will make $f(a x + b \xi) \neq a f(x) + b f(\xi)$.
The third example has a coefficient which is expressed as a product, but the function remains linear (just rename $w_3 w_4$ to $w$).
Miguel
  • 355
Your third example is certainly linear as we can simply imagine $W3.W4$ to be some $W5$.
Regarding your other 2 examples, you need to clarify what your input is. If your input is $f(x1, x2, x3)$ then they are not linear. However, say in the second example if the input to your function is $f(x1,x2,x1x3)$ then it is still a linear function!
You can refer to @Miguel's answer to test it out.
Anshul G.
  • 545
  • 10
