What is the difference between val_loss and loss during training in Keras?
E.g.
Epoch 1/20
1000/1000 [==============================] - 1s - loss: 0.1760, val_loss: 0.2032
On some sites I read that on validation, dropout was not working.
E.g.
Epoch 1/20
val_loss is the value of cost function for your cross-validation data and loss is the value of cost function for your training data. On validation data, neurons using drop out do not drop random neurons. The reason is that during training we use drop out in order to add some noise for avoiding over-fitting. During calculating cross-validation, we are in the recall phase and not in the training phase. We use all the capabilities of the network.
Thanks to one of our dear friends, I quote and explain the contents from here which are useful.
validation_split: Float between 0 and 1. The fraction of the training data to be used as validation data. The model will set apart this fraction of the training data, will not train on it, and will evaluate the loss and any model metrics on this data at the end of each epoch. The validation data is selected from the last samples in the x and y data provided, before shuffling.
validation_data: tuple (x_val, y_val) or tuple (x_val, y_val, val_sample_weights) on which to evaluate the loss and any model metrics at the end of each epoch. The model will not be trained on this data. This will override validation_split.
As you can see
fit(self, x=None, y=None, batch_size=None, epochs=1, verbose=1, callbacks=None, validation_split=0.0, validation_data=None, shuffle=True, class_weight=None, sample_weight=None, initial_epoch=0, steps_per_epoch=None, validation_steps=None)
fit method used in Keras has a parameter named validation_split, which specifies the percentage of data used for evaluating the model which is created after each epoch. After evaluating the model using this amount of data, that will be reported by val_loss if you've set verbose to 1; moreover, as the documentation clearly specifies, you can use either validation_data or validation_split. Cross-validation data is used to investigate whether your model over-fits the data or does not. This is what we can understand whether our model has generalization capability or not.
When fitting a model, you have the option to specify a portion of the training dataset that is not trained upon. This is separate from the test dataset.
The "val" in val_loss stands for "validation." It's a shame they didn't spell it out.
model.fit(validation_split=0.1)
# By default, this float is `0.`
Or you can explicitly provide the data to model.fit(validation_data=<see soruce code below>). This would seem to be a good idea if you want a stratified (equally distributed) validation set.
The use case for this is knowing when your model is appropriately fit to your dataset. Otherwise, you are just looking back and forth at the loss and accuracy of your train and test set wondering if it is balanced.
