There are
  • $k$ Boolean variables $x_1, x_2, \dots, x_k$.
  • $m$ arbitrary subsets of these variables such that sum of each set equals to $1$ (i.e., only one variable is $1$, the others are $0$). E.g., one of $m$ constraints may be $x_1 + x_3 + x_5 + x_6 = 1$.
  • $n$ arbitrary subsets of these variables such that sum of each set is at least $1$ (i.e., at least one of the variables should be $1$). E.g., one of $n$ constraints may be $x_1 + x_6 + x_8 \geq 1$.
The solutions are not necessary, but I want to know how many solutions exist.
What is an efficient way to calculate the number of solutions?
Ersin 101
  • 83
There is unlikely to be any efficient algorithm.
Your first class of constraints are monotone exactly-1 CNF clauses. Your second class of constraints are monotone CNF clauses. The monotone part indicates that negated literals aren't allowed (you can't have $x_1 - x_3 = 1$ or $x_1 - x_4 \ge 1$).
Thus, in the special case where you have only type-2 constraints, the problem becomes #monotone-SAT. Unfortunately, this problem is known to be hard. #SAT is #P-complete, and monotone #SAT is #P-complete as well: it is #P-complete even for monotone 2CNF clauses (i.e., type-2 constraints with only two variables). It is also known that it is NP-hard to approximate the number of solutions. As a result, there is unlikely to be any efficient solution unless the number of variables and constraints is fairly small. Of course, your problem (with a mixture of type-1 and type-2 constraints) is potentially even harder.
So what can you do, to make the best of the situation?
One approach is to code this as an instance of #SAT, and try applying some off-the-shelf #SAT solver. You can encode type-1 constraints in SAT using the methods described at Encoding 1-out-of-n constraint for SAT solvers.
Or, you could express the constraints as a BDD and then apply model-counting methods for BDDs. I expect this to perform worse than a #SAT solver, but you could try it.
Another approach is to use an approximation algorithm. There are existing algorithms for approximate-#SAT, though they too will hit a limit if you have too many variables and/or clauses.
D.W.
  • 167,959
  • 22
  • 232
  • 500
