-2
Let me explain my trouble by another example.
The wiki page says that
Lattice problems are an example of NP-hard problems
However, by clicking NP-hard, i find this definition
A decision problem H is NP-hard when for every problem L in NP, there is a polynomial-time many-one reduction from L to H.
What the fact? Lattice problems are not decision problems.
Edit after two answers: I think the two answers below have contradicting definitions:
1-)An optimization problem is NP-hard if it is as hard as NP-hard decision problems.
2-) An optimization problem is NP-hard if its decision version is NP-hard.
Which one is the real definition.
user
  • 111
In complexity theory, we often concentrate on decision problems. "Officially," NP-hardness is a category of decision problems — only a decision problem can be (or not be) NP-hard.
However, it is also common to use NP-hardness when referring to optimization problems. An optimization problem is NP-hard if its decision version is NP-hard.
In more advanced complexity theory, NP-hardness is used in a less precise way. For example, this paper "give[s] a new proof showing that it is NP-hard to color a 3-colorable graph using just four colors". They also prove that it is NP-hard to distinguish graphs of type A from graphs of type B (see their Theorem 3). What they really mean, in the former case, is that for any problem $L$ in NP there exists a polynomial time reduction $f$, outputting a graph, such that if $x \in L$ then $f(x)$ is 3-colorable, and if $x \notin L$ then $f(x)$ is not 4-colorable.
Yuval Filmus
  • 280,205
  • 27
  • 317
  • 514
Now that you have edited your post, your question is more clear ('cause let's be honest, it was very confusing before the modifications…)
By definition, problems in $NP$ are decision problems. However, $NP$-hard problems are not necessarily in $NP$ and even not necessarily decision problems.
Let's make an example of this. Consider the following decision problem:
Clique – Input: a graph $G$ and an integer $k$; Question: is there a subgraph of $G$ that is a clique of size $k$?
It is well known that Clique is a decision problem in $NP$ (and even $NP$-complete). Consider now the following optimization problem:
max-Clique – Input: a graphe $G$; Maximize: the size a subgraph $H$ of $G$; Conditions: $H$ is a clique.
Now we will prove that max-Clique is $NP$-hard, despite not being a decision problem. Indeed, if you know how to solve max-Clique, then given a graph $G$ and an integer $k$, you can solve Clique$(G, k)$ by running max-Clique$(G)$ and verifying if the result is greater than $k$ or not. This is done in an additionnal polynomial time. That proves that Clique $\leq_m^p$ max-Clique. Since Clique is $NP$-complete, we conclude that max-Clique is $NP$-hard.
Nathaniel
  • 18,309
  • 30
  • 58
