I work with poly-jet printed parts, more specifically, Stratasys objet pro, printed in Vero Black. The parts are always fully cured before taken off the bed.
We are sometimes required to sand these printed parts down once support material is removed. Is the dust given off during sanding (with sand paper or a Dremel tool) harmful similar to uncured material? can the dust given off whilst sanding still be carcinogenic if you breathe it in? or the fact that the material is cured makes it safe?
Just to add, it's only a few instances I've sanded to the point lots of particles are given off, usually its just a quick dash on the sandpaper.
JDeacon
  • 21
