I have a Ender 3 Pro V1. I installed the Bigtreetech SKR mini E3 V1.2 + TFT35 touchscreen + Antclabs BLTouch + a pre compiled bin from here .
  • the board works
  • the screen works
  • the BLTouch is erratic
    • A) it tries to exceed the X limits and makes the loud clicking sound while performing the bed leveling. it even tries to move past the X end stop switch.
    • B) when printing, it moves to the far right rear corner and extrudes off of the bed.
    • C) OctoPrint can no longer connect with the printer.
I think this is just a problem with how the bed size is setup and it identifying the limits of the print. I just can't figure out how to configure and compile a working bin file.
0scar
  • 37,708
  • 68
  • 156
spidr001
This tells me that the firmware you use is faulty - it has a faulty bed-size or home.
B)when printing, it moves to the far right rear corner and extrudes off of the bed.
This can be intended in the G-code, or bad homing, again, firmware home position.
C) octoprint can no longer connect with the printer.
This, again is a thing that happens if the firmware is not configured properly or flashed correctly.
You might have accidentally chosen the wrong firmware distribution - your config points to the Ender 3 - SKR Mini E3 v1.2 - BLTouch, not the Ender 3 v1.5 or v2 (slightly different hardware), and possibly adjust the proper homing position.
Trish
  • 22,760
  • 13
  • 53
  • 106
