I have established a multi-index pandas dataframe as per below:
import pandas as pd
GEN_power_vs_PF_index = pd.MultiIndex.from_tuples([('GEN PF', '0.85'),
('GEN PF', '0.9'),
('GEN PF', '0.95'),
('GEN PF', '1.0')])
GEN_power_vs_PF_columns = pd.MultiIndex.from_tuples([('Generator power at terminal, (kW)', 201875),
('Generator power at terminal, (kW)', 403750),
('Generator power at terminal, (kW)', 605625),
('Generator power at terminal, (kW)', 807500),
('Generator power at terminal, (kW)', 1009375)])
GEN_power_vs_PF = pd.DataFrame([(3217.6, 4259.1, 5847, 8024.1, 11059.1),
(3133.2, 4023, 5390.5, 7242.6, 9678.4),
(3045.4, 3791.7, 4954.4, 6538.8, 8564),
(2891.6, 3439.5, 4346.6, 5609.6, 7228.9)],
index=GEN_power_vs_PF_index,
columns=GEN_power_vs_PF_columns)
How do I search for an interpolated value from the dataframe, e.g. for a GEN PF value of 0.9769 and Generator power at terminal, (kW) of 736381.3?
I'm fairly new to pandas, and so far I've tried using the df.loc method, which is only good for looking up readily available data (without interpolation), and even then I wasn't able to perform a 2D search. I kept getting a Key Error.
