I'm using the ScrollReveal library to animate in sections of my site.
I have a pretty complex vector which contains five groups. I'm trying to animate these five groups in separately using this library.
Here is my approach currently:
My SVG is a bit lengthy and Stack has a body count character limit, so I created a demo using JSFiddle here.
Each group has a class and as you can see from the demo, it initially loads, then disappears. None of the reveal effects are working? I have other divs with the same parameters which work, but it doesn't work with this SVG for some reason?
If we inspect the white space, I can see that the parts are not appearing because the opacity is 0. But, on scroll, this opacity isn't changing and I don't want to force opacity to 1 via CSS as this I want the part to fade in nicely, whereas setting it to 1 will just make it a static image.
