I want to hide the index when pasting to this to sheet range
sheet.range('B22').values = dfHow can I hide the column names (
Data,Name)?print(df)Index Data Name 1 A X 2 B Y 3 C Z 4 D L
Asked
Active
Viewed 1,572 times
Note that you can control index/columns headers individually in xlwings like so: `sheet.range('B22').options(index=False, header=False).value = df`, see: http://docs.xlwings.org/en/stable/datastructures.html#pandas-dataframes – Felix Zumstein Oct 20 '18 at 10:09
When writing a dataframe to Excel, you can do the following to hide both the column names and indices:
df.to_excel('test.xlsx', index=False, header=False)
rahlf23
- 8,869
- 4
- 24
- 54
1I am using xlwings to achieve this. That is by place my data in specific range. How can i remove index from that range. – Raj Oct 13 '18 at 21:13
With xlwings use
import xlwings as xw
range1=df[['Data','Name']].values
wb = xw.Book('your_file.xlsx')
sht = wb.sheets['Sheet1']
sht.range('B22').value = range1
But, in general, using pd.to_excel can be easier. I think this is answered here [Python to_excel without row names (index)? and also here [Append existing excel sheet with new dataframe using python pandas
writer = pd.ExcelWriter('your_file.xlsx', engine='xlsxwriter')
df.to_excel(writer, sheet_name='Sheet1', index=False, startrow=21,startcol=1)
You can also add, 'header=None', to the to_excel function, if you want to drop 'Data' and 'Name'.
bart cubrich
- 1,184
- 1
- 14
- 41
Thank you, but I am trying to past the values in a specific range in an excel using xlwings. I then need to hide the indexes. Or it would be really helpful if we can just hide it from the dataframe – Raj Oct 13 '18 at 20:26
1I edited to include and answer with xlwings. Consider adding xlwings in the description of your question. – bart cubrich Oct 13 '18 at 21:41
