I have a DataFrame generated as follows:
df.groupBy($"Hour", $"Category")
.agg(sum($"value").alias("TotalValue"))
.sort($"Hour".asc,$"TotalValue".desc))
The results look like:
|Hour|Category|TotalValue|
| 0| cat26| 30.9|
| 0| cat13| 22.1|
| 0| cat95| 19.6|
| 0| cat105| 1.3|
| 1| cat67| 28.5|
| 1| cat4| 26.8|
| 1| cat13| 12.6|
| 1| cat23| 5.3|
| 2| cat56| 39.6|
| 2| cat40| 29.7|
| 2| cat187| 27.9|
| 2| cat68| 9.8|
| 3| cat8| 35.6|
I would like to make new dataframes based on every unique value of col("Hour") , i.e.
- for the group of Hour==0
- for the group of Hour==1
- for the group of Hour==2 and so on...
So the desired output would be:
df0 as:
| 0| cat26| 30.9|
| 0| cat13| 22.1|
| 0| cat95| 19.6|
| 0| cat105| 1.3|
df1 as:
| 1| cat67| 28.5|
| 1| cat4| 26.8|
| 1| cat13| 12.6|
| 1| cat23| 5.3|
and similarly,
df2 as:
| 2| cat56| 39.6|
| 2| cat40| 29.7|
| 2| cat187| 27.9|
| 2| cat68| 9.8|
Any help is highly appreciated.
EDIT 1:
What I have tried:
df.foreach(
row => splitHour(row)
def splitHour(row: Row) ={
val Hour=row.getAs[Long]("Hour")
val HourDF= sparkSession.createDataFrame(List((s"$Hour",1)))
val hdf=HourDF.withColumnRenamed("_1","Hour_unique").drop("_2")
val mydf: DataFrame =df.join(hdf,df("Hour")===hdf("Hour_unique"))
mydf.write.mode("overwrite").parquet(s"/home/dev/shaishave/etc/myparquet/$Hour/")
PROBLEM WITH THIS STRATEGY:
It took 8 hours when it was run on a dataframe df which had over 1 million rows and spark job was given around 10 GB RAM on single node. So, join is turning out to be highly in-efficient.
Caveat: I have to write each dataframe mydf as parquet which has nested schema that is required to be maintained (not flattened).
