to provide more precise information for playing through scripts, there are 3 ways to change sound volume in current version of omxplayer, and values are not so intuitive:
- on starting command line, param
--vol YYY, double millibels, default 0, range [-6000:0]
- by stdin interface, sending +/- to omxplayer will increase/decrease volume for 300 dmbels
- with DBUS interface, cmd 'set volume', value
double:XXX, default 1, range [0:1]
xxx to yyy relation is: XXX = 10 ^ (YYY / 2000) ... according to omxplayer.cpp source code, reverse formula would be: YYY = 2000 * (log XXX).
so if we need:
- volume 1%, XXX=0.01 and YYY=-4000
(10^(-4000/2000)=10^-2=0.01
- volume 10%, XXX=0.1 and YYY=-2000
(10^(-2000/2000)=10^-1=0.1
- volume 50%, XXX=0.5 and YYY=-602
(10^(-602/2000))~=0.5
- volume 100%, XXX=1 and YYY=0
(10^(0/2000)=10^0=1)
- volume 150%, XXX=1.5 and YYY=352 ... (for boost test, normal values are <=100%)
working bash script for dbus volume command:
export DBUS_SESSION_BUS_ADDRESS=$(cat /tmp/omxplayerdbus.${USER:-root})
dbus-send --print-reply --session --reply-timeout=500 \
--dest=org.mpris.MediaPlayer2.omxplayer \
/org/mpris/MediaPlayer2 org.freedesktop.DBus.Properties.Set \
string:"org.mpris.MediaPlayer2.Player" \
string:"Volume" double:0.5 # <-- XXX=0.5 (50% sound volume)
equals to volume parameter at startup:
omxplayer --vol -602 mediaFileName.mp4
... both sets sound volume to 50%.
