You need to bear in mind that an alter statement can add more than one column. If you look at the XML generated for an alter column statement you will get a better idea:
ALTER TABLE dbo.EventTest ADD NewColumn1 INT, NewColumn2 INT;
<EVENT_INSTANCE>
<EventType>ALTER_TABLE</EventType>
<PostTime>2015-06-30T14:28:30.790</PostTime>
<SPID>67</SPID>
<ServerName>XXXXXX</ServerName>
<LoginName>XXXXXX</LoginName>
<UserName>dbo</UserName>
<DatabaseName>XXXXXX</DatabaseName>
<SchemaName>dbo</SchemaName>
<ObjectName>EventTest</ObjectName>
<ObjectType>TABLE</ObjectType>
<AlterTableActionList>
<Create>
<Columns>
<Name>NewColumn1</Name>
<Name>NewColumn2</Name>
</Columns>
</Create>
</AlterTableActionList>
<TSQLCommand>
<SetOptions ANSI_NULLS="ON" ANSI_NULL_DEFAULT="ON" ANSI_PADDING="ON" QUOTED_IDENTIFIER="ON" ENCRYPTED="FALSE" />
<CommandText>ALTER TABLE dbo.EventTest ADD NewColumn1 INT, NewColumn1 INT;</CommandText>
</TSQLCommand>
</EVENT_INSTANCE>
So since you can add multiple columns, you need to check multiple columns, to get your columns lists you can use:
SELECT ColumnName = Cols.value('.', 'SYSNAME')
FROM EVENTDATA().nodes('EVENT_INSTANCE/AlterTableActionList/Create/Columns') x (Cols);
Then you could simply use EXISTS to check against a list of reserved names etc, and check for unwanted characters:
IF EXISTS
( SELECT 1
FROM ( SELECT ColumnName = Cols.value('.', 'SYSNAME')
) AS t
WHERE PATINDEX('%[.@!-]%', t.ColumnName) > 0 -- USE PATTERN MATCH TO CHECK FOR UNWANTED CHARACTERS
OR EXISTS
( SELECT 1
FROM dbo.ReservedColumnNames AS rc
WHERE rc.Name = t.ColumnName
BEGIN
RAISERROR(...)
ROLLBACK;
END
Another thing to consider is that sp_rename will fire a different event, and you probably want to track this too. The XML here looks like:
<EVENT_INSTANCE>
<EventType>RENAME</EventType>
<ObjectName>NewColumn</ObjectName>
<ObjectType>COLUMN</ObjectType>
<TargetObjectName>EventTest</TargetObjectName>
<TargetObjectType>TABLE</TargetObjectType>
<NewObjectName>NewColumn2</NewObjectName>
<Parameters>
<Param>dbo.EventTest.NewColumn</Param>
<Param>NewColumn2</Param>
<Param>COLUMN</Param>
</Parameters>
<TSQLCommand>
<CommandText>EXECUTE SP_RENAME 'dbo.EventTest.NewColumn', 'NewColumn2', 'COLUMN';</CommandText>
</TSQLCommand>
</EVENT_INSTANCE>
So here you would need to track it slightly differently, since it can only be one column at a time, you don't need to worry about nodes:
SELECT EVENTDATA().value('EVENT_INSTANCE[1]/NewObjectName[1]', 'SYSNAME')
WHERE EVENTDATA().value('EVENT_INSTANCE[1]/EventType[1]', 'VARCHAR(13)') = 'RENAME'
AND EVENTDATA().value('EVENT_INSTANCE[1]/ObjectType[1]', 'VARCHAR(13)') = 'COLUMN';
